Question about HP OfficeJet r40 InkJet Printer
OfficeJet R40 printer cable with a USB connection
I had to replace my PC and there is now no parallel port for the printer cable (only USB ports). Is there a cable that will allow me to connect my printer to my PC?
  • buchen2 Dec 13, 2008
    This is a great option. Although, I actually found this cable in town and it won't work. I need to have one end be a 25-pin male adapter and the other end be a USB connection.
  • Anonymous Mar 21, 2014
    the USB cable connection on the printer needs to be replaced
    President:
  • HP Master
  • 1,314 Answers
Yes there is. This is what you need.
Thanks and please take a moment to rate as fixya.
Posted on Dec 12, 2008
Need this cable hp c6680-80003 to usb
You can find that cable here: Buy HP Hewlett Packard C6680 80003 C668080003
However, you will need a separate adapter to convert from parallel port to USB. That can be found on Amazon. I've added a link below.
Dec 17, 2010 | HP OfficeJet r40 InkJet Printer
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer.
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_E250D&segment=DOWNLOAD&userlocale=EN_US#1 has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
Jul 01, 2010 | Lexmark E250dn Laser Printer
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Connect printer to PC
Dear! It is very to solve that matter use the USB converter for that solution and you can purchase a PC USB slot for that solution.
Thank You
Jul 27, 2009 | Epson LX-300 Matrix Printer
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Where to connect on computer
The printer will have one of two cables , either it is a USB cable , or an LPT cable
USB Cable Looks Like This:
The LPT Cable Looks Like This:
If it is the USB cable , it will connect to the back of your computer in a USB port, which looks like this:
It it is the LPT cable , it will connect to the back of your computer also:
Sep 29, 2008 | Lexmark Office Equipment & Supplies
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
HP OfficeJet r40 InkJet Printer Logo
1,126 people viewed this question
Ben Johnson
