Question about Audiovox FP1520 15 in. LCD Television
Found a burnt circuit in an LCD TV need to find a replacement.
I'm working on an Audiovox 15" LCD TV for a friend and found a circuit board P/N AP-1514S-AO burnt. Are there other suppliers besides the factory for this item?
  • 944 Answers
These guys are talking about stocking an AP 1514 - hopefully is the right board give them a try http://www.anachip.net/products/DATA/AnachipIC.pdf Hope this helps :)
Posted on Mar 07, 2007
I have a samsung tv with aound and no pic made checks that i found on the Internet. Found that i have no backlights ao which board do i replace .model # un32eh4003fxza
It is the backlight that is burnt out not the circuit boards, pull it apart and check also where the backlight connects if that connector is burnt replace it also.
Jun 28, 2016 | Samsung Televison & Video
AUDIOVOX fpe3707hr power lights up blue screen but no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 07, 2017 | Audiovox Televison & Video
Is there a fuse and where on 32 audiovox, no power
Open up the back of the set and follow the power cord feeding the TV, it should be connected to the circuit board which will be the power supply module.
Look at the power supply first; look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Dec 06, 2009 | Audiovox FPE3000 30 in. HD-Ready LCD...
Tv power comes on but no picture th name Audiovox
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Dec 01, 2009 | Audiovox FPE3206 32 in. LCD Television
Flat tv, sound but no picture. have tried
I had one that had a black screen and fixed the problem by repairing the inverter. When I opened the unit I looked at the capacitors on the inverter board and found them swollen. I looked at the bottom of the board and found that the fuse had opened up. The caps were a cheap quality low temp variety 150uF at 25V I replaced them with 330uF 25 volt 105C caps. I then replaced the 2.5A surface mount fuse with an axial 2.5A pico fuse and the TV worked beautifully.
Jun 12, 2009 | Philips 15PF5120 15 in. LCD Television
The sceen just bleaches out when powered on. Controls have no effect. TV is 13 months old.
I took it apart and found two 330 mfc 25volt swollen capacitors on the main board. I replaced them with 330 mfc 35volt capacitors and tv works like new.
Feb 11, 2009 | Audiovox FPE1506DV 15 in. LCD TV/DVD Combo
Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Oct 08, 2008 | Audiovox FPE3206 32 in. LCD Television
Flat panel tv
I had a similar problem, except I had sound and with a flashlight I could see audiovox when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Aug 16, 2008 | Audiovox FPE3206 32 in. LCD Television
Audiovox FPE3206
I had the same problem on my Audiovox FPE 3206, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Apr 22, 2008 | Audiovox FPE3206 32 in. LCD Television
Audiovox FP1520 15 in. LCD Television Logo
146 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
