Question about Dryers
Maytag dryer quit working
My Maytag Electric dryer stopped working. It worked fine this morning but would not turn on at all this evening. The interior light comes on but nothing else happens.
  • 36 Answers
Check your braker turn off then back on
Posted on Dec 12, 2008
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
My dryer runs fine, just wont heat, was working fine this morning, but on my second load of the day it stopped heating, cleaned all the lint from front-even pulled out and cleaned the lint from the back...
heatman101
Apr 30, 2011 | Bosch Nexxt 500 Dryer
Doesnt dry clothes, every opening i have unclogged,even outside vent is clear.basket rolls but heat is room temp. no matter what setting.
Hi, I experienced the same problem with my Maytag electric dryer. I finally fixed the problem after I checked the actual vent pipe (which allows air to discharge to the outside of your home). What I found was quite surprising. I found was a mouse nesyt in this pipe. Once I removed the mouse next,m my electric dryer worked fine. Just a thought. Good Luck!
Jan 09, 2011 | Roper REX4634KQ Electric Dryer
Maytag 2007 model mdg308daww quit working
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 30, 2010 | Maytag MDG308DAWW Gas Dryer
Maytag Dryer quit working mid cycle
sounds like the timer,the only thermal fuse i know of is to protect from overheating which cools and resets itself
May 10, 2009 | Maytag PYE2300AY Electric Dryer
Dryer was working, quit in middle of cycle. Will
It's rather unusual for any internal failure to cause the dryer to just stop in cycle. Check the circuit breaker that supplies the dryer. It should be a double-pole breaker of at least 30 amps. Turn the breaker off and back on to ensure it is reset. Internal causes could be the motor, door switch, thermal safety switch, timer, or a broken wire.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Some days electric dryer works fine and others it won't start
If you can get to the timer, spray a good electronic contact cleaner inside while rotating the dial. Also check the door switch for solid mounting and sung wire connections.
Apr 11, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Dryers Logo
Top Dryers Experts
