Question about Symbol MC1000 Barcode Scanner
Low program memory
The device always prompt the window ststing that "program memory is low.
No response whenever what key I pad.
And the device cannot be explored by the connected PC...
Thanks for helping me.
  • leeweileang Jan 06, 2009
    i also facing the same problem. Please help!!! Thanks.
How to resolve the memory low system
Hi Anon, this is Microsoft's answer to low memory messages, and I would only add the suggestion that you check for viruses and other unwanted programs hogging your computer's memory. How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
    For more information, see What information appears in event logs (Event Viewer)?
Top of page
Aug 10, 2014 | Acer Aspire E1-472G-6648 Misty Silver 14"...
Why thers always prompting in my screen of low memory disk?
open the task manager to see the ram-usage. This series do not have alot of memory, therefore several tasks running at the same time can make this message pop up. You might have to many startup programs activated, change settings to start programs manually.
Oct 08, 2013 | ASUS Eee PC 1000H Laptop
Memory problems
  • Install more RAM
Mar 08, 2013 | Dell VOSTRO 3350
How to transfer applications installed in my device to my media card?
  1. Connect your device to your computer
  2. Run the installation program from your computer. The installation program will prompt you to install the software application to your device using ActiveSync or Windows Mobile Device Center.
  3. Select whether to install the software to the device memory or to your memory card
Feb 21, 2012 | RIM BlackBerry Storm 9530 Smartphone
Low phone memory and how to refactory setting
Go to Start -> Settings, then under the System tab, click on Hard Reset icon followed by 'Clear all data'. And when it prompts users to confirm the action, just key in the correct Device Lock Code (default is 1234) and it will do the rest.
If Device Lock Code has been altered or changed, you may want to consider the second option. As relatively easier as compared to the first option, just press both the Send and End key (on both left and right of your mouse pad) and while holding them, use a stylus to poke on the 'Reset' button and release it (while still holding down both the Send and End key) until a Format Screen is appeared. Then, press the Send key to format the phone. If you are not aware, there is actually a third option that you can try which is mainly relied on the soft Dial Pad on your Samsung. After you are in Phone mode, just dial *2767*3855# and within seconds the smartphone will restart that will restore it into default factory settings immediately.
Hope this solves your problem.
Mar 03, 2011 | Samsung OmniaHD i8910 Smartphone
Everytime I press graph it says "ERR:WINDOW RANGE"??? It never did that before and now I always get prompted for some reason?
Go to Memory. and Reset all Memory. This will take care of the problem.
However, if you have programs that you don't want deleted. Go first to memory, manage programs, and hit enter by each one to lock it.
Dec 06, 2010 | Texas Instruments TI-84 Plus Calculator
Always prompted that memory is full.
heres how
you can put *#7370* - hard reset
or you can restore using the following buttons * key, a number key 3, green/call key : hold all of them down at the same time and power on your device do not let go off the buttons until you see the nokia screen or handshake screen only then you can let go and the phone will restore the original state, you will lose all your data on the phone
Jan 17, 2010 | Nokia N73 Cellular Phone
Toshiba l300 1bv bios password forgotten
Download and flash your BIOS to the newest version for your make and model. You have four to choose from. There are known issues with Toshiba BIOS's, this is one of them.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Hope this helps.
Edit: some notebooks use "Toshiba" or "toshiba" for their password.
Or try this: From Toshiba website http://tinyurl.com/dkoudz
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key.
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
this might be what you are after
http://www.pwcrack.com/bios.shtml
Also have you read through this site?
http://www.tech-faq.com/reset-bios-password.shtml
Dec 16, 2009 | Toshiba Computers & Internet
X-keys and Window XP SP2 x64 (64-bit)
Hi guys,
Unfortunately programming in Memory Resident Mode on Vista will not be supported, however if you program your unit on an XP or 2000 machine first you will be able to “run” your unit on Vista.
Because we are unable to program in Memory Resident Mode in a Vista environment we are currently moving to new firmware called MWII which supports a mode called Boot Mode. Boot Mode is very similar to Memory Resident Mode in that when operating in Boot Mode all of your X-keys device's macros are stored in the X-keys device's internal memory. Our MacroWorks II software is required to write programming to an X-keys device operating in Boot Mode or to read programming from that device.
I apologize for the inconvenience this will cause. If you have any questions for me please email me at: Roccol@piengineering.com
Sep 28, 2007 | P.I. Engineering X-keys Destkop Keyboard
Can't download my photos
your memory card has a virus! try formatting using camera. make it a habit that whenever you reinsert the memory card in your camera format it first before taking shots, this will erase everything including virus! you may also try another memory card. Check also your pc, are you sure you didnt install any program recently? Some program installed may have conflict with another program like in your case.
Sep 01, 2007 | Olympus Stylus 710 Digital Camera
Symbol MC1000 Barcode Scanner Logo
81 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
