Question about Rockford Fosgate T10001 bd Car Audio Amplifier
No sound no protection light no obvious problem...
I have a RF T10001 BD amp and 4 pioneer 12's I have all the wires connected correctly the subs still do not hit at all the protection lights on the amp is not on I have checked my RCA cables for splits etc...my friend came over and connected his head unit to my truck and the bass worked until he turned up up loud then stopped....turned my truck off back on and tried agian and now same thing as my original head unit we switched preamps still no thump...took the whole system out and put it in his truck and it works perfectly?.....that has stumped me for hours... = (
Your help would be GREATLY apprecieted
  • blueextc3221
    blueextc3221 May 11, 2010
    did you check the voltage at the amplifier with a voltmeter to ensure 14V from your charging system?
    Assuming each sub has 4Ohm SVC, your load is down to 1 ohm wired parallel.
    The proper wiring would be mixed Series-Parallel to achieve a 2 Ohm Load.
    That amplifier is not 1 ohm mono capable.
    The current draw from the aplifier @ 1 ohm may not be able to be accomidated in your vehicle. Trucks usually have larger alternators.
    Scholar:
  • 96 Answers
There is a wiring issue in your truck and i would get rid of the preamp
Posted on Jan 10, 2009
Lights up & getting no power to subs
for a test
disconnect everything from the remote terminal in the amplifier
get a bit of wire and connect the remote terminal to a 12 volt supply
does it turn on now?
if yes then check the remote wire from the radio does it become 12v when the radio is on and 0v when it is off
if no make sure that the amplifier has been grounded properly and all the power cables are connected properly
Dec 31, 2009 | Rockford Fosgate T10001 bd Car Audio...
My amp is protecting unessacarily when ran at 2 ohms
are you factoring the ohm rating from running them parallel?
2 x 2o subs parallel = 0.5 ohm (lowers ohm's)
2x 2oh subs series = 4 ohm
IT is posable that you are calculating the ohm rating fine, BUT some SUBS can reach lower ohm rating while hitting bass- i didnt know this till i had a rather insane sub that would dip to 1ohm while hitting hard bass causing my amp to go into protect mode.
May 21, 2009 | Rockford Fosgate T10001 bd Car Audio...
Pioneer 800w mono issue
It can be many things it possible the amp cannot handle the 4 ohm load and simply goes into power protection mode. Also make sure your using the correct gage wire to run power from your battery to the amp to thin and it wont have enough power to perform.
May 09, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Mar 17, 2009 | Rockford Fosgate p-450.4 Car Audio...
How do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Mar 10, 2009 | Pioneer TS-W307D4 Car Subwoofer
Best sub For RF T10001
There is no "best" its a matter of opinion, and fabrication. I have installed $75 subs in the properly fabricated and tuned enclosure that sound like $300 sub in a pre-fabbed enclosure. For volume, you will need a vented enclosure. For sound quality, a small sealed. Both have pros and cons. SoloX 10 is 2500W rms 5000W peak.
Kicker is plastic. Solobaric may be your best choice in such a small space, however soundsplinter makes an 8" RLi sub that will kick a$$ in the proper enclosure.
When looking to buy, compare x-max : as this is the linear distance the cone will move. More movement = more air displacement = more volume.
Dec 13, 2008 | Rockford Fosgate T10001 bd Car Audio...
Pioneer GM-7200M 800 Watts Mono Amplifier
you Amp is overloading and going into protection mode. if it cuts out with the wire u were using first then their would be no need to upgrade the size of ur wire cause that would only be, doubling or trippling the power u are getting threw those wire now. bottom line the 2 subs u are using are obviously to much for the amp. try dropping the OHM's by connection the subs together and runnig just a single positive and negative to the amp! or just get a better amp
Mar 19, 2008 | Pioneer GM-7200M Car Audio Amplifier
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Rockford Fosgate T10001 bd Car Audio Amplifier Logo
101 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
