Bulb was shutting down, so I purchased a new bulb [in the assembly], installed it, but it won't light up. I can hear a fan inside, so I assume the color wheel is turning, but the bulb itself won't light up. On the front panel the LAMP green light flashes on and off, then the TV turns off. It cycles back on, then all three light [two green and one red] come on and flash. Any good ideas?
He just stated that the ballast was replaced already. maybee theres an engine problem. the color wheel should not be hard to turn. the new wheel may have defective bearings id either take it apart and swap parts with the old wheel that are known good or if its under warranty best yet get it replaced with another unit.
id like to find a way to get a suitable hack thatd substitute my bulb in mine(maybee a few track lights?) anyone have any suggestions?
Replace the lamp ballast next.
I have the same problem....Can anyone help? I have changed the color wheel and bulb.
Thanks,
Mike
I just pulled out my new color wheel and it does not turn easy. Would this keep my bulb from lighting? I really need your help as my tv has been down for weeks.....Thanks, Mike
red] come on and flash. Any good ideas? Exactly the same problem!!
I just removed my new color wheel to make sure it was okay amd the wheel is a little hard to turn...should it just spin freely? will this cause my tv to not turn on? I need your help, please....My tv has been down for weeks. thanks, mike
okay....I have replaced the color wheel, bulb and ballast and my bulb will not come on....What next?
I have replaced the ballast and still keeps starting and turning off and the bulb will not turn on.
Could the new color wheel be causing the problem? It worked great for three days and then the screen went black.
Thanks,
mike
installled mew bulb. lamp doesm't light. what does it mean when the green lamp light keeps flashing?
