Question about HP LaserJet 1320n Printer
Paper is jammed in the printer and cant move it
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Remove the cartridge, lift the plate below the cartridge, open the rear door and lift the green lever on the side and release the paper.
make sure the setting in the toolbox is set to
Tray 1: Any size / Any Type
tray 2: A4 size / Plain Type
Rgds,
Nikhil
Posted on Sep 17, 2009
Fix a paper jam
Printers have a series of 'flags' usually near to the middle of the paper path, these are just little black plastic pegs that are moved when the paper goes through. If one is stuck or trapped with even a tiny scrap of paper then you will get a paper jam error.
Whatever printer you have, start looking for these sensor flags and ensure that they are all free to move.
Dec 19, 2014 | Office Equipment & Supplies
Paper jam on display but there's no paper jam
Then the roller are dirty or need to be replaced because they cant grab the paper so the machine is miss feeding jam is when the paper hit something or stop electrically move to different draw or the by pass
Jul 25, 2012 | Minolta bizhub 200 All-In-One Printer
MY HP PRINTER SAYS I HAVE A PAPER JAM BUT I CANT FIND ANY PAPER JAMMED. WHEN I TRY TO PRINT ITMAKES A NOISE LIKE WOODPECKER PECKING ON A TREE. HOW CAN I GET IT TO WORK AGAIN
Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
Look for paper through the opened back panel. Remove any paper you find jammed.
Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
Close the front access panel. Make sure that it latches back into place.
Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Take care.
Jun 07, 2010 | HP Photosmart C6180 All-In-One InkJet...
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Canon pixma mp150 saying paper jam but cant see one
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
HP 2360 Paper Jam
pls look the swich for paper inside, maybe the switch did not tuns back to his position
Oct 15, 2008 | HP Deskjet 2360 InkJet Printer
Paper jam
Try bellow steps to resolve paper jam.......
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Have any other queries.. please let me know..
Thank you....
Oct 11, 2008 | Lexmark X83 All-In-One InkJet Printer
Paper jam...
Aug 18, 2008 | Lexmark X2350 All-In-One InkJet Printer
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
Paper jam Brother MFC-215C
Norman,
does the printhead run smoothly to the left side of the printer when it is powered on?
If the printhead cant run that freely, it will give you the paperjam message. You have to dismantle the printer again, connect the scanner and cables again when top cover is removed. Press the scanner open contact (opposite to the menu button) and watch the printhead run to the left side. It might be that either the printhead stucks somewhere on its way (press the cover of the printhead. It might be the reason) or the guide rail hinders the printhead to move.
Oct 13, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP LaserJet 1320n Printer Logo
137 people viewed this question
Ben Johnson
