Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
Dishwsher is getting no water?
I have a KitchenAid dishwasher model number KUDIO1ILWH6. It retails for @ $600.00 and Lowes has a unit that is very similar. I believe the dishwasher I have is from 2005 or 2006? I don't know a lot about it because I bought it used and was told that it worked. I got it all hooked up and it ran all through the cycles without using any water? I fooled with the button sequence some but nothing. I decided to try the water solinoid valve, so I bought and installed one of those. Still nothing. I checked online for information and saw somewhere that some dishwashers need some water in the motor housing in order to work. It was completley empty when I installed it so I put water in it, ran it some, pushed cancell to drain the water and then started over again and it worked! Well.......the next I would say two times. Now it hasn't worked again since then. I also tried replacing the float switch, but that didn't work either. Any ideas would be greatly appreciated. Someone took the repair manual from the inside of the lower panel so I'm really begining to wonder if there was a problem before.
  • 1 more comment
  • cmoll61 Dec 12, 2008
    I didn't try what you said but I took my tester and checked the voltage going to the water valve when the dishwasher was on. It got spikes of electric but it was so fast it never even got up very far on the meter. My guess is the valve isn't getting a full signal? So what's the problem? I loooked at the drawings and the only thing I can figure is the control pannel? I also took the top pannel apart some and checked the two switches on the latch and they both work. I made sure the tab is bent down as far as it will go to activate them when the door is closed.
    Where's the timer? I don't remember seeing that? I need to get a schematic. Where can I get one?
  • cmoll61 Dec 15, 2008
    Thanks a lot for your time. It turned out to be something totally different! Even though I checked water coming in at the water solenoid I guess it was only a small build up? It turned out I had a shut off valve that the rubber seal came off and got lodged in the opening blocking the water! I discovered it only after I took the dishwasher out I was trying to install and put my old one back in and then that one wasn't getting any water either. I couldn't believe it when I took it apart. The water started running out when I turned the main off and the pressure dropped but when the pressure was holding it in place it sealed it right up!
  • 71 Answers
Can you make a test cord out of a short extension cord . cut the cord on the female end and crimp on two alligator clips . now with the dishwasher disconnected from the power grid put the alligator clips on the water valve .check that the alligator clips are not touching nothing but the valve terminals. Now plug up the male end into a wall outlet ,you should have water if not you will know what to test.
Posted on Dec 12, 2008
  • flyingtarzan Dec 12, 2008
    sounds like the timer . trace the schematic and use the ohm scale to test the contacts in the timer the ohms should be 0 or close to 0 . Use the wire colors to help you trace
  • flyingtarzan Dec 13, 2008
    your have a controller instead of a timer part #8564542 this part is around 100 dollars. your model # is KUDI01ILWH6. the tech sheet could not be found yet.
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Our KitchenAid dishwasher started making scary baby cry sounds. then a few months later the clean dishes would have a white film over them like dried detergent didn't rinse.
Hello Cindy;
My name is peter. I am a retired field service appliance technician.
You need to provide a model number so I can see what you have. The model number is on a tag on the front face of your dishwasher after you open the dishwasher door.
You may want to remove the bottom front panel on your dishwasher, run the dishwasher and observe. There are two clip pins on the top of the bottom panel. Push in with a putty knife or something similar. Pull on the top of the panel on both sides, then lift the panel up.
Jun 08, 2015 | KitchenAid Dishwashers
Kitchenaid kuddo1dppa
test this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 22, 2013 | Dishwashers
I have a kitchenaid quiet scrub dishwasher that fails to function. When you close the door and press the start button the clean and cancel lights come on and the pump starts up. No water enters the...
ther is a small impulse pump on the bottom of the unit. the diaphram gets old and it stops functioning but sometime then it leaks . so if it's not leaking , turn off water suppl and remove the fitting for incoming water some have screens right here and they get plugged with hard water debris . ha dont be silly all water is dirty.you can get new screens at h/d and lowes, hope your solenoid still works, check it by putting a finger on it when the cycle should start it should humm or vibrate. diaphram is not replaceable. need to buy new valve
Sep 06, 2012 | KitchenAid Dishwashers
What are the dimensions?
You are missing a digit in the model number. KitchenAid Dishwashers have a number (0-6) after the SS.
The KUDI01FLSS0 installation guide gives the dimensions of the dishwasher opening and the unit itself on various pages. See http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208524480.pdf . The top vent and the front vent KUDI01FLSS model washers are slightly different. The front vent dishwasher dimensions are 33 7/8" H (with the wheels removed) x 23 7/8" W x 24 7/8" D (including the handle). The top vent model is only 24 1/2" deep. With the wheels in their lowest position, the opening for the dishwasher must be 34 1/2" high (from floor to the bottom of the counter top).
I hope this helps. Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Use the search box to enter the model number and use the drop down menu to select Consumer.
Aug 14, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Amana dishwasher Manual
Amana has many of its appliance manuals on their support site: http://www.amana.com/content.jsp?pageName=CustServ . However, I can't find the above model number.
I found models ADU6000DB and ADU6000DWW. The manuals for these have not been uploaded to Amana's site. I also found the Whirlpool models DU6000XR* and DU6000 with the manual here: http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20304281.pdf . There is also a Amana Master Clean, DU6000BR, with the manual here: http://www.kitchenaid.ca/assets/pdfs/literature/R0913017.PDF .
I hope that your dishwasher is similar enough that the manuals above help you use your appliance.
Mar 19, 2012 | Dishwashers
I need to fit a new drain hose to my Bosch Dishwsher Model No. SGS546A72/42 . Is this easy to do and can I obtain a diagram to assist.
not all models use the same size drain hose. you need to know what size the out put of the unit (could be found in the user manual or measure the outside diameter of the outlet on the unit.) also you need to know what is the size of the connection to the drain on the pipe under the sink or where ever it is located. it is also best if you know the length that you will need don't go short a little extra can usually be better than to short. with all of the above written down on paper go to the hardware store (I like Lowes) and have the store person show you what he has for your dishwasher. I like to put clamps on the hoses as it keeps them inplace and will eliminate future leaks.
Jun 21, 2011 | Dishwashers
The unit fills and pumps out OK. However, the wash arm does not shoot water or rotate. The unit model is listed as KUDSo1FLSS2 and the serial number is FP4117644.
IT NEEDS TO BE CLEAN THE ROTATION IS CAUSED BY THE WATER PRESSURE. THAT STOPS WHEN ITS CLOGGED WITH BUILDUP... YOU CAN GET A MANUAL THAT HAS THE INSTRUCTIONS AT TVPARTSANDMANUALS.COM
Jan 12, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwashers Logo
226 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
