Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
All cycles run cold
I have a 4-yr-old F&P EcoSmart washer that seems to like only cold water. We have checked and double checked the hook-ups. The inlets are not reversed, it simply fills with cold water no matter what temperature setting I select. Our water heater is fine--we have hot water everywhere else in the house. It did this once before about a year ago. That time I disconnected the power, plugged it back in a while later and it seemed to reset itself. I tried that again this time, but to no avail. Any suggestions?
Thanks for your assistance.
Karen
  • 750 Answers
Hello
Welcome.
Faulty Water Inlet Valve
The water inlet valve is the device that meters water from the supply lines into your wash tub. On domestic washers, there are two lines, one hot the other cold. These valves are susceptible to mineral build-up and sediment deposits. There are two common failure modes:
Failure Mode One: Valve will not open.
If you can verify that the solenoid on the valve body is receiving the requisite voltage and the valve will not open, then it is faulty. Since the solenoids operate independently, it is likely that one side of the valve will work and the other will not. This can produce strand results such as a very hot wash when warm is selected (due to no cold water). Or the reverse in that the wash water is cold when warm is selected. If mineral or hard water deposits are a problem, you may witness a substantial increase in the time required for the tub to fill. This is caused be a decrease in the flow ware of the valve.
Failure Mode Two: Valve opens but will not close.
This is verified by a valve that allows water to flow into the tub even though no power is being supplied to the solenoid. This one is usually quickly diagnosed when the machine begins to overflow and the power plug for the washer is disconnected from the wall. However, this will not stop the water from flowing into the machine. The water must be shut off at the wall. As with the previous failure mode, the variant of this failure mode is that it may take the valve a while to completely bridge the flow of water after the power has been removed from the solenoid.
How to Diagnose?
There are a couple of ways to diagnose a faulty valve. However, there is a simple test that one can perform that will usually let you know if the water inlet valve is faulty.
Scenario:
When set to cold wash and rinse, the unit will not fill. When set to warm wash and cold rinse the washer will fill with hot water only and will fail to rinse. This is a common scenario where the cold water side of the valve does not appear to be contributing to the fill, but the hot water side does. This symptom could be easily reversed where cold water is being supplied, but never hot water.
So, how can the problem be determined? It is as simple as switching the wire harness plugs on the hot and cold side. In the example above where the cold water is never being supplied, the symptoms would be the opposite when the wiring harnesses were switched. So the machine would produce only produce cold when warm or hot is selected. No water should be present when you select cold. This verifies that the timer, wiring and switches are all in working order. Assuming this tests checks out, you simply need to replace the water inlet valve.
Recent Customer Symptoms:
I have a Kenmore Washing Machine. My question is if I set the washer on cold was and cold rinse it will not fill with water but if I set it on hot wash and cold rinse it will fill with Hot water and wash normally but when it comes to rinse with cold no water will fill and will go to the spin cycle assuming that it had filled with water. There is water in the cold water source. Any idea??? I was assuming the timer but not to sure.
Thank you , Huum
Please remember to leave a solved rating before you sign off !
Posted on Dec 12, 2008
How do I get cold water only to run in my W10550314B washer? Just purchased 4 days ago
Newer washers only way to run cold water only would be to use a Y adapter off cold water supply and hook cold to both hot & cold to washer other wise some cycles will not work
Mar 24, 2015 | Kenmore Washing Machines
The machine won't sart. the code seems to be an L , followed by an F duet GHW9150POW the timer sounds to be running & cycle sset to cold/cold w/ only cold water hooked up. cycles briefly through...
If that is a new unit the hot water has to be hooked up as it will take in a small amount of hot water even on the cold cycle. whirlpool strarted this a while back due to energy use..try hot water let me know.....good luck.........
Jan 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
2 yr old Whirlpool duet washer,suds and now f35 codes. Also when put on cold water i can only get hot water ?
the only reason you would get hot water on the cold setting is if the water lines have been crossed.you can usually clear the cosde by running nothing but clean water through the wash cycle and then use a little less soap.on the next was cycle.unplug the unit for a little bit then wait awhile and run the washer empty.
Nov 17, 2010 | Whirlpool Washing Machines
Error code NF? what does that mean?
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water.
Try running the diagnostic test by—
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Fisher Paykel Ecosmart washing machine spills water.
sometimes too much detergent, or extra cleaners like oxy clean) will cause lots of foam which will cause the water level sensor to misread, or foam over the top of the drum. if this is not the problem, you will have to tilt the machine on its side and look for loose or damaged hoses. the play in the tub will not cause leaking
Jul 10, 2009 | Washing Machines
I have a 1.5 yr old Fisher Paykel ecosmart washing machine. During the past 2 loads there has been a notable water leak (significant puddling on the floor). I haven't witnessed the problem, but there is...
the play in the tub in normal, it sounds like you have an over sudsing issue, run an empty load with 3 cups of vinager in the tub, set the water temp to hot, cut way down on soap, if you use liquid dont even fill the cup 1/3 of the way, I know this sounds dumb but try it, I have one and this happened to me
Jul 10, 2009 | Fisher and Paykel Washing Machines
My washer wont run in the hot water cycle
Sounds to me like your water valves in the back are going bad, just had it happen on mine the other day, I bought one online for like 15.00 that was new solinoid valves for both hot and cold water. took about an hour to install with no instructions (take the old one out, new one hooks up the same way) or call the washer repair people.
Mar 18, 2009 | Whirlpool Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
take hose and siphion the water out of the unit.run into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
thanks,
joyce
Feb 07, 2009 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
309 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
