Question about Sony KP-57HW40 57" Rear Projection Television
Blue Screen and TV shuts off
Intermitently, TV screen turns blue, then TV shuts off. Also, screen starting to go red now too. I've been told there could be a "short" that needs to be repaired on blue tube and other tubes...not sure I'm phrasing this correctly.Does this sound right? Is the TV worth fixing or should I just get a new one? TV is model Sony KP-57HW40 and is about 5 yrs old. Thanks! Mary Jane
  • 1 more comment
  • joeypalms Jun 11, 2008
    I have the same tv and the same problem. Can an adjustment really fix it? I s it true about the warranty extension from Sony? Also, what is code 4?
    Thanks,
    joeypalms
  • Anonymous Jun 29, 2008
    Redish screen with lines accross it, I removed the two front covers and very carefully adjusted one knob at the time for a couple of times having another person looking at the screen to let me know if I'm doing better or worse. it work it does not need much adjustment, I started with the bottom right knob first then I moved left to the next one and that was all it need it.
  • Anonymous Jul 08, 2008
    blue screen and tv shuts off and tv go on for a few seconds and turns blue
Sony has a warranty extension on this until august 2008. They will pay for free to fix this problem.
Posted on May 18, 2007
  • 38 Answers
Check the CRT board first then if you find it O.k. the picture tube is defective!
Posted on Mar 14, 2007
I had the same problem but now I have another this tv is garbage. Anyway your problem is free and easy. Pop off the two screw covers at the front bottom and unscrew. unscrew the next cover. There are six adjustments you need to turn the blue down a little bit. It is one of the bottom ones. Make sure you mark all original positions.
Posted on Mar 12, 2007
    Problem Solver:
  • 18 Answers
The solution here is of course to never buy sony again. After paying $3000 for this set and having the tubes go bad - Sony should reimburse or fix this set. I own one and the same problem is happening. This is a design flaw or manufacturing flaw and SONY should stand behind the product they make NEVER BUY SONY AGAIN. John
Posted on Mar 11, 2007
  • John Schuholz Aug 13, 2007
    sent my set to tech for repair - tubes R no longer available. How does a company sell a product and then drop support for it after 4 years. NEVER BUY SONY AGAIN.
    President:
  • 1,284 Answers
Yes, you are correct on the phrasing. The CRT's were a common issue with these units and all three must be replaced as sooner or later the green will follow the other two CRT's. It was a great model and had a beautiful picture when operating normally. The CRT's are costing about 200 each for rebuild as the green and blue are mostly no longer available. Your repair cost are going to approach $1000.00 or more.
Posted on Mar 10, 2007
  • Don
    Don Mar 10, 2007
    Sorry to give you the bad news there...
Hi
Is this true , that Sony will cover the cost of repair, warranty extension until august 2008?
My Sony 51" kp-51hw40 has a blue screen then turns blank.
The sound is still ok. The diagnostic code is AKB 1 and HV 1. The Red LED on the font of the tv blinks 5 times.
Please help. I contacted Sony by e-mail and they only gave repair tv services in my area.
Thank you,
shelbyss@yahoo.com
Posted on Apr 07, 2008
SyncMaster SA10, my screen turned green, i've tried everything but it's still the same. Help ?
The Blue and Red drives are missing and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Samsung SyncMaster 940MW 19 in. LCD...
The tv turns on - the screen is red - sound is working
sounds similar to mine (blue) I am told its a faulty crt blue tube.
Jan 05, 2010 | Sony KP-57WS500 57" Rear Projection...
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Jul 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony turns on and off again
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
Apr 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Blinking red power light - set will not turn on
Were the pale blue lines real thin in a slight diagonal from bottom to top of your screen? If so you either have a bad component in the blue drive, Blue CRT socket or your Blue CRT is shorted.Try removing the blue CRT socket and trying to power up your set for a moment without the blue socket attached to the tube. Be sure the CRT socket doesn't touch any components when you try this. Let me know if the set starts up without the blue.
Jan 23, 2008 | Televison & Video
Blue Screen
Your blue crt has a short - you can verify this by unplugging the socket from the blue crt and powering up the set and you should see a yellowish looking picture with just the red and green crt's operating. You can try turning down the screen control pot (B) for blue with the blue crt on (just to the point where you no longer see retrace lines in the picture on a blank input)Sony has had a lot of problems with the crt's on these models and sooner or later all the crt's will fail - For a permanent repair all must be changed.
Aug 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Blue screen
It sounds like the high voltage distribution block but that is not the cause of your problems,the tuners you talk about are the picture tubes ,one for each color,the blue picture tube was arking and you got lucky and got 6 more months of use, it and might have corrected when you drop it but now is the red doing it and you need to do the same but it might not work this time,dont be surprise.Be carefull while trying things in the back,there are high voltages there and is not safe unless you are familiar with tv service.
Sep 19, 2006 | Sony KP-61V45 61" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
252 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
