Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable dryer makes squealing sound. need to find out where to get replacement belt. heard people say open it up and replace the belt but we dont know where it opens up.
    Genius:
  • 1,028 Answers
Probably not belt most likely rear drum bearing which means a complete tear down of dryer from front console,rop and front panel will have to be removed then drum will need to be lifted up out of bearing cup belt removed part is avaiable from sears .com or local parts house unit is made by fridgedaire
Posted on Dec 12, 2008
Dryer runs for a short period then starts to sqeal from the back and when you stop it and open the door you can smell a burning smell .
sounds like a bad belt and or pulley. If you take the top of the dryer off you can use a piece of candle wax to lube the belt and see if that makes the squealing stop to verify the belt/pulley as the source of the squeal. If so, you can but a new belt and pulley kit for about $30 and replace yours. Good Luck!
Oct 11, 2014 | Kenmore Dryers
Kenmore dryer will not work
the motor will make a sound if working so if heard check for a broken belt that surrounds the drum inside
May 14, 2010 | Kenmore 63942 Dryer
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
My kenmore dryer is making a squealing noise. It is 5 to 7 years old
This sounds like it could be the tensioner pulley is worn or needs a drop of oil, or the drum rollers need the same. If they are worn too much they will need replaced. If the tensioner pulley is stiff, replace the belt as well.
Jan 03, 2010 | Kenmore 62882 Electric Dryer
Squeaky Kenmore Dryer
The idler rollera and belt tensioner have got bearings. One of them is failing.
Jul 07, 2009 | Dryers
Loud rubber squeal sound with new clothes washer water seal.
its the wrong seal. do not lubricate it at all rubber sweals with any kind of petrolium product. many door boots look right for the model but will be thicker then needed. and will cause rubber to hit the basket.
Feb 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 417.81042000 Electric dryer has loud squealing sound
My dryer of the same model number had the same issue. The teflon/plastic wear points are worn out or have fallen off. They are about $22.00 plus shipping at the site below. Disconnect the power, lift (with force) the top off at the front of the dryer and you will have access to remove and replace.
Felt glide assembly - Upper felt seal with three glides attached. Comes with adhesive.
Part Number: AP2150497 made by FRIGIDAIRE
www.appliancepartspros.com/modelsearch_model.aspx?part_id=2150497&&model_id=301211
Oct 30, 2008 | GE DBL333EA Electric Dryer
Dryer Squeals
my sears kenmore 417 stacking get things caught every time in the dryer and leaves some brown stuff on all my clothes.
How can I keep things from getting caught??
Jul 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
726 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
