Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Ground coffee Saeco Royal
Intermittent problem. After pressing the button/s for a coffee the grinder continues to grind beans and the grinding simply drop into the overflow tray below the brew unit.
Has been happening for a few years. Only solution I have found is to remove the brew unit and give it a good shake. The unit is clean and serviced regularly.
  • Anonymous Jan 04, 2009
    Same thing. About every 3rd or 4th shot, the machine grinds a dose, I hear the the brew unit make a tamping sound, but no coffee. It's a waste!
  • 1,089 Answers
Hi
thedalys. you probably have a bad micro switch on your doser. and that just needs to be replaced. If the grinder does not sense that the doser box is full it will keep grinding until it times out.
Guest. Try pulling the dosage lever back one click from the full and push your grind lever to the largest # and see if that helps. Sounds like you grinds are too fine and its clogging the the grind box. If the dosage level is too full it will cycle and dump the brew unit or break the brew drive gears, then you will hear a clicking noise when it trys to make a coffee.
Posted on May 24, 2009
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Why aren't the beans being ground?
try pushing the beans into the grind mechanism while it is grinding or turning the grinder knob but only when grinding, or try different beans
Jun 10, 2014 | Saeco Incanto Classic Espresso Machine
DCC-790 Cuisinart coffe maker won't grind
what showing on display ,when push to make coffee? If showing grinder block-then you have to replace the grinder to fix it. Try to grind coffee ,but without beans-if grinder start but rotate slowly -you have to replace grinder and change the brushes of the motor.
Oct 04, 2013 | Saeco Royal Professional Espresso Machine
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Saeco Machine needs looking at...
you here the grinder motor if yes the grinder might be full of old coffee stuck on the theth where it grind be carefull with our hand push the coffee bean while making a expressoyou force the bean to go in it will clean the grinder it get cloaged oily coffee use or old coffee pierre
Dec 07, 2008 | Saeco Royal Professional Espresso Machine
Machine will not grind beans.
I had the same problem and Saeco recommended that I clean the grinder. Check this link for instructions.http://saecooutlet.com/instructions/Grinder%20Cleaning_Magics_Royals.pdf
Jul 15, 2007 | Saeco Royal Professional Espresso Machine
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
223 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
