How do I fix a faulty PC connection on an ipod?
hey my ipod nana modelA1137 has frozen up and is stuck on HD Info: model number: but wont let me write it in and wont let me go 2 my media player on my ipod what should i do???
\If this reset does not resolve your issue please let know
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
my Apple ipod play each track about 10 seconds then goes to play next track automatically then play...
(More)
my Apple ipod play each track about 10 seconds then goes to play next track automatically then play and do all above again
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
