Question about Fender Stevie Ray Vaughan Stratocaster Electric Guitar Microphone
The back of my Fender Stratocaster, where you put the strings in, is too far off from the back slot to put the strings in or out and the whammy bar won't screw in all the way
    Problem Solver:
  • 5 Answers
I'm guessing that in addition to your explanation, the guitar does not have currently have strings on it and you want to replace them. If so, this will fix your problem and is generally the best way to restring a floating bridge strat:
1) Remove the metal plate from the back of the strat. Inside you'll see the springs and the back of the bridge. Get yourself a thick piece of paper (or an ace of spades card like I do ;) and hold the guitar on your lap like you're going to play.
2) Gently push the back of the bridge up a bit and slide the paper/card in between the body and the back of the bridge on the front of the guitar. This will give you the room to get the strings through and slide the tremelo bar in correctly.
3) Restring the guitar starting with the low E, bringing it into pitch and then repeating in order with the other 5 strings. The card will fall out as the strings begin to put tension on the bridge. Replace the back plate and rock out vigorously.
Cheers,
NTIMID8
Posted on Dec 14, 2008
I'm trying to find out any information on a Fender Stratocaster made in Japan serial# N017378
This is a good info site....
http://www.xhefriguitars.com/page14.html
Mar 04, 2015 | Fender Music
Where can you buy a whammy bar for a fender squier?
Guitar center for Cheap Used..I believe I got a new fender stratus (spelled wrong)amp for 199.99 or something
Jan 02, 2011 | Fender Squier Std Strat Mn Car
Hi , what type & size of whammy bar do i need to replace a standard yamaha erg 121 please. thanks Becky
Any standard screw in whammy will work they're the same as a stock Fender Strat.
Good luck, Cody J.
Dec 12, 2010 | Yamaha Electric Guitar
15th fret sounds completely flat
Here is a link to the instructions you need:http://www.fender.com/support/stratocaster.php Pay particular attention to Intonation Roughing It Out section. Hope this helps.
Jul 09, 2010 | Fender Squier Std Strat Mn Car
I have a Fender Squier Strat. The Whammy bar is
There are MANY tricks to remove a threaded piece like this:
1. With a Dremel tool and a cutoff carborumdum disc cut a shallow slot in the remaining piece and use a straight bladed screw driver to remove. This can only be done if the screw is above or flush with the surface.
2. Carefully drill a small hole in the piece fairly well centered. Use an "EasyOut" to remove the broken part.
3. Carefully drill several small shallow holes on the top of the broken part in a line so as to form a slot for a screwdriver.
4. Carefully drill a hole JUST the right size into the broken part and then drive an Allen wrench into the hole to turn the broken part. The hole has to be just the right size so the wrench can peal tiny pieces off to grab the broken part.. this is tricky to get the size just right.
5. Use a detist drill to cut a slot.
In all these use a penetrating oil or CRC226 to make it easier to turn.
Mar 08, 2010 | Fender Squier Std Strat Mn Car
Factory specs for Fender Stratocaster and Squire
The nut and the bridge are the pieces that effect the radius of a guitar, regardless of make/model.
The radius is the arc the frets and fretboard follow from side to side. Matching this arc with your string saddles greatly increases playability and comfort when playing the guitar. The nut follows this arc also, though not as intensely as the saddles. An improperly set bridge not only is hard to play on, but causes undue stress on the player!!
Fender does not provide the specifics; it's pretty much up to the player to set to their preference. I'd check out a music store to see what a new out-of-the-box Strat is set up like, just for reference.
Nov 09, 2009 | Fender Stevie Ray Vaughan Stratocaster...
My tele tuners have a slot in the tuners. I am
Usually you have either loops or little metal spools in loops at the end of the strings. The little spools are put down into the slots to secure the strings. If your old strings have the spools, you can remove them and put into your new strings.
Sep 29, 2009 | Fender '72 Tele Deluxe Electric Guitar
I dont know how to put a whammy bar on a fender stratocaster
Look near the near the highest string at the the silver part known as the bridge.There should be a hole right near the bottom of the thinnest string.Take the threaded end of the whammy bar and screw it in clockwise into the body.
Sep 20, 2009 | Squier Stop Dreaming Start Playing...
Bridge problem
There are different tension strings available. Contact your guitar store to find the right weight strings for your guitar as a first step.
Aug 02, 2009 | Fender Classic '50s Stratocaster Electric...
Need help putting my guitar together
The "handle type thing" is a Tremolo or, more often referred to as a "whammy" bar. The thing at the base of the strings is called a bridge. Looking at the strings, there should be a hole to the right of the smallest string. If your "handle" is threaded, stick the threaded end into the hole and rotate in a clockwise motion. Once is hits the bottom of the threads, back it off one turn and gravity will let it hang out of the way while you play. If there are no threads, it will slip in and you will feel a "click" when it's in the proper position.
On the back of the guitar, there is a cover plate that covers the cavity where the springs are located that make the "whammy bar" work. The springs hold tension on the bridge so you can tune it and play normally, but let the "whammy bar" stretch or release tension on the strings when you push or pull it. If you already have springs inside the cavity, the extra spring you have will let you add more tension to the bridge, but you probably won't need it. If there are no springs already installed, you can install your "extra" spring in there to give you the flex and spring for the "bar-handle" to work properly.
To install a spring, loosen or remove your guitar strings, open the cover on the back, and install the spring over the hooks on the bridge and the hook on a metal bar on the other end of the cavity. Replace the cover, insert your "handle", and wiggle-away.
The allen wrenches are most likely for adjustment of the moveable pieces that support the strings on the bridge. The bridge has adjustments for up and down, and forward and back to adjust the height and distance where the string is supported. Don't adjust the bridge supports unless you loosen the strings. It is highly recommended that you don't make any adjustments yourself unless you are familiar with the mechanism. You can adjust your guitar where it's impossible to keep in tune if the adjustments are not perfect. There are usually guitar repair shops close by and offer "set-up" services to get your instrument adjusted properly. It's well worth the money to have it done right, and the service people with often teach you many things that will help keep your instrument playing well.
Hope this helps.
Jim
jimmydsmith@cox.net
Phoenix, Az
Jan 10, 2009 | Fender Squier Std Strat Mn Car
Fender Stevie Ray Vaughan Stratocaster Electric Guitar Microphone Logo
139 people viewed this question
Top Fender Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rick Moore
Rick Moore
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
