Question about Arris DCT6200 DTV Receiver
Motorola Dual Tuner PVR - DCT 6412-III --- HELP
I own a Motorola Dual Tuner PVR - DCT6412 - III . I am having a problem with the recording on my unit . I can record a current program in progress only . It will not record any single FUTURE programs nor any serial programs that I have set up . I should say that it was working fine for the past year and all of a sudden developed this problem . The little red light comes on to indicate that the recording has started at the appropriate time but nothing gets recorded. I have gone to the channel that is supposed to be recording and when I hit the OK button on the remote it should indicate a recording is in progress but all I get is a message that says " One moment please this channel should be available shortly " and the screen is black ( no picture ) . I had a friend come over with his unit to determine if it was a line problem from the provider that was causing the problem or if it was my unit that was faulty. His unit works perfectly so it is definitely a problem with my unit .The provider tried several times to resend the signal to see if it would correct the situation but that did nothing to correct it . I contacted Motorola Tech dept. and they indicate it is likely a problem with one of the tuners . Where can I bring this unit for repair in Windsor , Ontario , Canada as the provider ( Cogeco ) will not help in any way as the unit is no longer under warranty . ?
  • 4 more comments
  • CAWwindy1 Dec 12, 2008
    d04 Information
    In Band Tuner 1
    Mode : 256 QAM
    Carrier Lock : Yes
    PCR Lock : Yes
    Data : Yes
    Freq : 0717.000 mhz
    SNR : 34.7 db - Good
    5 sec error count :
    Uncorrectable : 000 Correctable : 000
    In Band Tuner 2
    Mode : 256 QAM
    Carrier Lock : No
    PCR Lock : No
    Data : 0639.000 mhz
    SNR : 0 Invalid
    5 sec error count :
    Uncorrectable : 0 Correctable : 0
    d06 Information
    Tuner 1 Status : Acquired and Locked
    Tuner 2 Staus : N/A
  • CAWwindy1 Dec 16, 2008
    I have supplied the info you requested (mt_smith01) with regard to diagnostic readings for d04 & do6 but have yet to hear back from you , although I did get an e-mail asking me to rate your answer to my problem . Do you have an answer ?
  • CAWwindy1 Dec 21, 2008
    In Band Tuner 1
    Mode : 256 QAM
    Carrier Lock : Yes
    PCR Lock : Yes
    Data : Yes
    Freq : 0717.000 mhz
    5 sec error count :
    In Band Tuner 2
    Mode : 256 QAM
    Carrier Lock : No
    PCR Lock : No
    Data : 0639.000 mhz
    SNR : 0 Invalid
    5 sec error count :
    d06 Information
    Tuner 2 Staus : N/A
    In Band Tuner 1
    Mode : 256 QAM
    Carrier Lock : Yes
    PCR Lock : Yes
    Data : Yes
    Freq : 0717.000 mhz
    5 sec error count :
    In Band Tuner 2
    Mode : 256 QAM
    Carrier Lock : No
    PCR Lock : No
    Data : 0639.000 mhz
    SNR : 0 Invalid
    5 sec error count :
    d06 Information
    Tuner 2 Staus : N/A
  • CAWwindy1 Dec 23, 2008
    mt_smith01 ----are you out there ? Have you seen my information above that you requested ? Any ideas ?
  • mt_smith01 May 11, 2010
    CAWwindy1,
    I need a little more info from the 6416's diagnostics menu. With the unit powered on, press the POWER botton on the 6416 (not the remote) then immediatly press the SELECT button. You might have to press select one or two times to get it.
    If you don't see DIAGNOSTICS at the top of the page, press the left arrow button on the 6416 once.
    From the diagnostics main menu, use the down arrow to get to d04 (inband status) then press the right arrow. Look at Tuner 1 and Tuner 2 and please let me know what it says for Mode.
    In d06 (current channel status) you will want to see what it says for Type and Status for both tuner 1 and tuner 2.
    When all done, you can just hit the power button again to get out of the diagnostics mode.
Hi.
The information provided shows that tuner 2 isn't working at all on at least the selected channel. This could be a problem on just some channels with this tuner or possibly all channels. You can verify this by hitting the "SWAP" button on the remote to switch tuners while viewing a live program on a problem channel. If you choose the same channel for each tuner, I expect you will see program on one and "one moment please" or freezing or pixelation on the other. The confusion about recording comes about because of how the DCT6412 chooses which tuner to use for recording versus viewing. If you activate record on a channel you are watching, it will use that tuner. If you see it, it will record. For future or series recordings though it will automatically choose to use the alternate tuner so that it won't have to change your channel selection. Since there is no input signal detected on the other tuner, it will actually record but there will be nothing to see on play back. What causes this? It is probably that tuner 2 has failed. There is a slim chance that your cable signal coming in is either too strong or too weak but this is unlikely since the DCT6412 splits and then amplifies the cable input signal before distributing essentially equal signals to both tuners (the plug on coax adapter on the back feeds the cable signal to an AGC amplifier within the DCT6412 and then splits and distributes that output to both tuner inputs). You could check the OOB AGC level as described here http://www.cable-help.com/ but I think your problem is more likely that tuner 2 has gone bad. JM Belleville Ontario
Posted on Dec 31, 2008
    Problem Solver:
  • 5 Answers
As a cable provider stand point if your PCR does not lock then you will not recieve the correct signal from your provider which controls the HD functions and TV programming functions. Ie... Temp of Air or black screen.... Have your cable provider to check Mer and Ber signal behind the set and at demark and tap. If mer and ber is not in specs the the PCR will not lock to carrier there for setting box for shut down mode of functions controlled by pcr.......All this sounds crazy but if you have a good cable provider tech he/she can troubleshoot the issue and corrcect the problem
Posted on Oct 27, 2009
2 Suggested Answers
SOURCE: Motorola Dual Tuner PVR - DCT 6412-III --- HELP
I was just reading another blog on this problem and it seems you must clear any recording setup you have for the program the go to the settings and in the history file delete all listings of it. This can take a while as you must delete them one at a time. Then you can reset the series or single recordings. Seems to work for some people. I am having the same problem and programs are disapearing one at a time. Good Luck
Smalltown
Posted on Mar 08, 2011
How use Tivo on Motorola DCT6412 III?
this works to record progam you watching
1. press menu key
2. highlight DVR button by using either < or > key then press OK button
3. answer prompts
Do this to set up a recording in advance or a series recording
1. Hit the guide button
2. scroll thru channels until you find program you want to record
3. scrool over to red dot press OK button
4.you can the highlight red dot for one time recording or go down one to record every episode. make sure you check the settings for this program.
Hope this Helps.
Mar 19, 2009 | Motorola Televison & Video
Smalltown
Feb 24, 2009 | Arris DCT6200 DTV Receiver
Motorola Dual Tuner PVR 6412-III ( HD )
If you cannot get it repaired, note that it has a 120GB disk-drive -- very small when compared to the latest model (500GB), and note that the disk-drive probably is approaching 10 years old -- doomed to "fail" soon. Replace it, and add an external-SATA "Expander" to add another 1000GB of storage of recordings.
Dec 11, 2008 | Dell Inspiron 6000 Notebook
DCT6412 DVR Box
When that happens its most likley you had a power outage and the box reset.  Well kinda reset but not all the way.  You can unplug the power and wait about 10sec and plug it back in and wait a few min to a few hours, and If that doesn't work get a new box.
Oct 04, 2008 | Arris DCT6200 DTV Receiver
Recording TV shows
Since it doesn't have a tuner, it will not be able to store channels - it will only record the channel that your cable or sat box is on currently
Aug 19, 2008 | Philips Magnavox DVD/VCR Dual Player
External tuner
if it's possible attach a free-view box to it.
Jul 29, 2008 | Philips Magnavox DVD/VCR Dual Player
Arris DCT6200 DTV Receiver Logo
3,726 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
