Question about kawasaki Full Suspension Mountain Bike Men
1996 kawaswaki bayou carb. leaks gas from btm. when running
The fuel leaks out the carb. overflow tube whit ti is running is there an adjustment for the fuel level in the carb or does it need to be torn down?
  • Anonymous Mar 19, 2014
    carbs were cleaned in carburator acid and are good
  • 36 Answers
Ues handle of screwdriver lightly tap on bowl if the leak stops use lucas injector cleaner in tank
Posted on Dec 12, 2008
After engine is started fuel flows out of carb vent tube
Hi, Lou and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Carburetor is leaking gas out of overflow tube need help
http://www.instructables.com/answers/What-is-wrong-with-my-carburetor
gas pouring out of bowl vent hole and overflow tube on super Harley...
RM125 Carb keeps running fuel out overflow
Concours Owners GroupTM Sport touring at its finest SM
Dec 12, 2016 | Motorcycles
Why is bike flooding and pushing gas out top over flow hose on carb after it runs for a min or two. Carb float been replaced still doing it.
Hi, Paige and the usual suspects are:
For more information about your issue please visit the websites below. Good luck and have nice a day.
My carb leaks fuel out of the overflow hose at the bottom of my carb
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY..
Carbs leaking Here is how to fix it
Mar 28, 2016 | GAS Motorcycles
Why am I still getting fuel coming out of the over flow pipes ?
Hi, Nigel reset your float height to 21mm obviously thats not the problem and the other usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day. xlch@mail.com
How to adjust the Float Height on Carburetor Metric Harley and Asian
http://planetminis.com/forums/klx110-drz110-ttr90/180657-gas-coming-out-carb-overflow-tube.html
Mar 23, 2016 | Motorcycles
Gas leaking out overflow tube as soon as petcock turned on fuel running out of overflow tube,running or not
If you are saying the fuel is leaking out of the carb overflow tube it would likley be that the float and/or needle and seat are stuck or defective
Jun 10, 2014 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
Won't Idle. Fuel from overflow.
Hi, Anonymous and the usual suspects are:
3 4 leaking carb after rebuild XJ550 Maxim
Yamaha Motorcycles Leaking Maxim Carbs Maxperience
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Nov 13, 2013 | 1985 Yamaha XJ 700 X Maxim
Overflowing Carbs again!!!
recheck and clean /adjust floats pet **** doesnt stop fuel in bowl if floats out of adjustment or valve sticking/debris will allow fuel to constant flow
Jun 04, 2017 | Suzuki Motorcycles
Fuel overflow on Ducati ss800 2005. Today I rode for a while, then stopped. After the stop, the fuel was running down from the overflow drain even with the bike off. The tank was not over filled.
Hi, Kakarostan and the usual suspects are:
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.
http://www.ducatimonster.org/forums/tech/153769-gas-leak-carb-overflow-tube.html
Fuel leaking from Carb Ducati ms The Ultimate Ducati Forum
Ducati Supersport 800 1000 Workshop Manual Repair Manual Service Manual...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
May 10, 2012 | 2004 Ducati SS800
Fuel dripping from overflow tube
Since 1996, Harley has used a vacuum operated petcock that is supposed to cut off the fuel when the engine is not running. If fuel constantly drips from the overflow hose when the engine is not running, you have two problems.
One, the vacuum operated petcock is leaking. Either repair or replace the petcock with a manually operated petcock like a Pingel.
Two, your needle and seat in the carb is leaking. You need to have a qualified mechanic inspect the needle and seat in your carb.
Good Luck
Steve
Sep 05, 2010 | Harley Davidson XL 1200 C Sportster Custom...
I have a 2006 Kawasaki Bayou 250 it is always fowling spark
Take the carb back off and adjust the float in bowl to spec.If you don't have spec just adjust till fuel stops overfowing an go with that.Yeah, it might take a few times.
Mar 21, 2010 | 2006 kawasaki KLX 250
kawasaki Full Suspension Mountain Bike Men Logo
286 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
