Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Kenmore Elec. Dryer Model 66912 (1996)
Dryer will not start when you push the "push to start" relay but there is a loud hum for about 10-12 seconds, then nothing. Occurs on all cycles, cannot push again until switch appears to cool. Continunity on thermal fuse, operating thermostat, thermal cutoff, and high limit thermostat all check closed. Could it be the belt switch ? Afraid it might be the motor, if so how do I go about to remove it ? Do I need any special tools ? I have the exact same problem - I changed the belt, but that wasn't the problem
  • 71 Answers
The problem is the motor switch . Try spinning the drum with the door switch held in and pressing the start button all at the same time .If the problem is lint in the switch that might be all you have to do . If that don't work you will need to replace the motor and no special tool required. I can walk you through it.
Posted on Dec 12, 2008
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Kenmore 80 series dryer makes loud humming noise when it is drying clothes think it may be a belt that needs to be replaced
More likely is that your motor is going bad...that will make a very loud hum when it starts to go...
DryerRepair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Nov 07, 2010 | Kenmore 65924 Electric Dryer
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Jun 01, 2009 | Dryers
Drum turns hard after holding start button down and has a loud hum
that is a sign of the dryer motor going bad,it will fet to the point where it will not work at all just hum when you push the start button,time for a new dryer it's not worth fixing-mike
Apr 28, 2009 | Kenmore Dryers
No air...drum not turning...Kenmore elec.dryer # 110.62822011
does it make a humming sound if so you may have a bad motor os something stuck in the blower wheel
Jan 10, 2009 | Kenmore 62602 Electric Dryer
if its a humming than a click,,wont start for a few mintues,,than the hum again ,,your motor is shot,,,replace,,onthejob
Jan 05, 2009 | Kenmore 62872 Electric Dryer
Kenmore dryer hums but will not start
If it just hums the motor is probably on it's way out. If it makes a growling noise, it's the motor.
Nov 04, 2007 | Dryers
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
145 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
