Question about Archos Jukebox Recorder MP3 Player
Does Not Turn On - wrong charger ma?
I have a Jukebox recorder 20, it was working fine and accepting a charge from a like charger that was not the correct charger. the correct charger supplied 650 ma and the one i was using supplied 800, otherwise other specs were correct. it started cutting out within an hour after charge and other strange behavior, so i located the correct charger and then it would not accept further charge, saying that it was fully charged. then it would not power on at all. all that i get now is a flashing green light when i try to power up. when i connect it to the charger, the green light flashes repeatedly, on second on, one second off. i have tried and succeeded to run it entirely out of power, and then to charge it again, but it is still the same result. i have opened it up and am totally lost at what i found inside, i am not an electronics kind of guy. i was hoping to easily pull the battery and maybe reset it, but i can not even find the battery without breaking solder, which i am not really good enough to do. has anyone seen this problem? does anyone know a repair place that won't totally rip me off? i only paid $70 for this unit. is it time to buy a new unit?
    Top Expert:
  • Archos Master
  • 82,322 Answers
Sounds like the battery is defective.
Posted on Mar 03, 2017
SOURCE: Unit Frozen After battery replacement
I came up with a solution (finally!). Only try this if you have exhausted all other possibilities.
First, make sure the unit if turned off, remove the backplate, and set the battery aside, still connected. Peel back the gold foil where hard drive connects to the motherboard, and loosen the small silver plate at the other end, sliding it to the side. Remove the hard drive by sliding it off the pins. Turn the unit on, and you should get a screen that asks if you would like to reformat. Replace the hard drive, carefully, and quickly, and reformat.
I had to reformat twice, but I eventually got the thing working. I was almost ready to toss it, so any extended life I get is worth it. If nothing else, this should get you off the dreaded logo screen. Good luck!
Posted on Jun 25, 2008
Petryxa
  • 40 Answers
SOURCE: Keeps shutting down.
The solution is found! There's no need to format your HDD
So.
- Unplug the battery;
- Press and hold the reset button for 20-25 sec;
- Put the battery back to it's place;
- Charge your device (when you plug the cable in, it turns on (note that a blinking lightning icon appears on the charging indicator), then it turns off with it's "shutting down" message, dont pay attention on this, just let it charge for about 10-15 minutes (note that the CHG bulb won't be lit));
- Turn on your device. The CHG bulb is lit, Archos doesn't shut down
- Enjoy
Posted on Jul 22, 2008
andy1958
  • 14 Answers
SOURCE: archos 5 60gb won't charge
How old is your unit? Maybe your battery is dead The one good thing about having a Archos 7 is that you can change the battery easily. Have you backed up everything on your archos? I hate to say it but you might want to try repair , recovery or your last gasp format the unit.
Try using the tools/settings/customer assistance function first. I have not had good luck with tough problems using that function, you might have to do a hard reset.
Posted on Aug 24, 2009
IPOD tech
  • 61 Answers
SOURCE: my archos 7 wont charge the red light comes on but
If the archos was purchased new from Archos stores they have warranty on them call tech support to find out. Have your serial number and product model number handy.
Posted on Sep 14, 2009
SOURCE: Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Posted on Jan 09, 2010
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
AMI Jukebox Lifter Arm Problem
Dave - I have the same problem, how do you replace the trip switch? I got the part, but it appears it needs to be soldered?
Aug 27, 2012 | Audio Players & Recorders
Lost my manul for archos jukebox recorder 20 mp3 player/recorder & data storage
Go to the RockBox software site. RockBox is provided freely by an end-user created and supported group and is a wonderfully evolved software replacement for quite a few portable music-playing machines. Your Archos Jukebox recorder is long out of warranty, so there's NO downside in updating it by installing the most current version of RockBox. That will greatly extend the capabilities of your machine.
Then download the RockBox user Manual! That will be your new Archos JukeBox Recorder User Manual. You'll be able to select what you hear by one of two control strategies: File names or by Playlists. You'll be able to adjust playback sound in new and more powerful ways than just using the equalizer. Also it will allow you to control playback "pitch" or speed, so you can hear lectures or books at a higher playback speed. Human retention actually improves when playback speed is increased some. You can print out the RockBox pdf. format manual if you'd like or you can study it on line. Lots of choices.
Good luck with your "obsolete" Archos JukeBox. I actually prefer the earlier models which were powered by four rechargeable AA cells rather than those with the replaceable lithium battery. I know someone who ran one of these continually for more than a year to provide background music, plugged into a wall-wart charger and his sound system. Durable!
John
Sep 23, 2010 | Archos Jukebox Recorder MP3 Player
What is the max mA battery rating that can charged by the Bc700?
Divide the mA of the battery by the mA you want to charge it at.For example,I'll use the 3000mA battery at a 500mA charge.That would be 6 hours.However,that only actually charges it to 80%(for alkaline).It needs another 6 hours to charge the remaining 20%.If they are not alkaline let me know and I will look and see what I can find out.
May 07, 2010 | La Crosse Bc700 Alphapower Battery Charger...
The DVD player was working fine and now will not turn on and will not charge (the on/charger light does not come on even when plugged up).
Try a new charger/adapter. Walmart sells universals.
Just make sure of +/- connections and volts and mA ratings on the adapter
Apr 18, 2010 | Venturer PVS8380 Player
Yamaha YPT310 use of wrong adapter fried fuse won't power up
1200 ma provides more power than the 700 ma, and would not be affected by using it on a device that draws 700 ma. The voltage of the charger makes a difference as well as the polarity of the plug. (if it is dc)
If the 700 ma charger is not working, most likely the 700 ma charger is not working
Sep 16, 2009 | Yamaha Portable Keyboard with 61...
What is the wright technique in Charging NiMH AAA and AA Cells?
Should work. As long as the voltage is correct the components of the charger should work. Depending on the type of "end of charge", i.e., time, voltage drop, temperature, it may take longer to charge with lower power ratings.
Aug 27, 2008 | Panasonic CR2016 Lithium Coin Battery
Archos Jukebox Recorder MP3 Player Logo
57 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
