Question about Nintendo Wii Console
Our Wii remotes are not working. - Nintendo Wii Console
  • ngaasbeck Feb 14, 2009
    Our WII remotes are not working. We replaced batteries to no avail. HELP!
    Problem Solver:
  • 19 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any Technical knowledge. I hope this guide will solve your problem. It also gives Information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 21, 2009
My wii remote doesn't work at all I have brand new batteries in it but it still doesn't turn on. Is there a way I can fix it?
Wii Remote Won't Sync ' Nintendo Tech Forums
techforums.nintendo.com > Wii & Wii mini > Discussions
Dec 29, 2011 - 14 posts - ‎13 authors
I used a digital camera and all lights are working on the sensor bar. Both have new ... That doesn't work obviously. ... I've tried everything on this post and everything that I could find online to resync my remote. Nothing works. Wii Remote Doesn't Work Properly on Wii...
Dec 25, 2013
Wii remote doesn't sync and light up...
Feb 6, 2012
Wii-mote issues - won't sync
Jun 28, 2011
Wii remote doesn't work...
Aug 20, 2010
More results from techforums.nintendo.com
Dec 26, 2015 | Video Game Consoles & Games
Cant use the remote
The remote has to be sync'd with the wii properly. If you sync it with another wii you have to sync it back.
Open the battery cover on the wii remote.
Open the front cover door in the middle front.
In each you will see a Red circle sync button in the remote and a rectangle button above the memory slot on the wii front.
Turn on wii, press the sync button on front of wii, then press sync button on remote, the remote should then get a signal and blue lights on front show player #. If not, turn off and try again. Once sync'd it will work with that Wii.
May 09, 2010 | Nintendo Wii Console
My handsets wont sincronise with the system, I have fitted new batteries
Follow this procedure:
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
* If multiple Wii Remotes do not work, or you only have one Wii Remote, a repair of the Wii console is necessary.
Oct 20, 2009 | Nintendo Wii Console
Wii remote works but not for wii sports
If you're wii remote works as a pointer but not when swinging it then it is a problem with the accelerometer inside the wii remote and not the infra red bit on the end. Good news is its usually just stuck as mine was. Nintendo recommend turning the remote upside down and giving it a few taps on the palm of your hand. Worked on mine and saved me £30 as i was about to buy a new one.
Aug 04, 2009 | Nintendo Wii Remote Controller
Why are my remotes not working
dont have a wii fit but, try to reconnect the remotes by pressing the button with the blue house on it on the wii remote, and pull up the wii remote settings. then, press the reconnect button on the remote and follow the directions. if that doesnt work, open the battery compartment on the remote and when the wii is on, press the red button inside the battery compartment on the wii remote that says SYNC. if that doesnt work, try the SYNC. button inside the wii itself. (located in the door in the FRONT of the wii. it has a spot for an SD (scandisk) memory card) it is a rectangular bigger button than the wiii remote. even if none of these options work THANKS FOR READING
Apr 19, 2009 | Nintendo Wii Console
Wii remotes cant get synchronized
Press the red button near the SD card slot then press the red button undre the Wii remote's battery cover to synchronize again.
Feb 28, 2009 | Nintendo Wii Console
Wii remote not working.
Get some regular alkaline AA batteries and try your Wii Remote using them -- the blue lights on the Wii remote should light up and register with the Wii console (this is via wireless / bluetooth) -- As for the sensor bar, it is really only an infra red emitter - so if you have it properly connected to your Wii, the Wii Remote (with working batteries) can sense where it is by "seeing" the lights emitted from your sensor bar.
If the alkaline batteries work - You may need to get some new NiMH AA batteries to use in your charger - changers are usually third party devices; Nintendo does not ship charging stations with the Wii.
If the Wii remote appears to be working (blue lights and all) and your sensor bar is properly connected, you may have a dirty or damaged IR port. First clean the top of the Wii remote, just to make sure. If it still does not work, borrow a friends Wii Remote and check to see if it works with your system. If you do everything above and your Wii remote does not work while a seperate one does, the problem is most likely a broken Wii remote.
Jan 01, 2009 | Nintendo Wii Console
Wii
check wii console is connected then insert wii fit cd and see what happens put new batterys in remotes and make sure wii works before installing wii fit
May 26, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
98 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
