Question about LG 24 in. LDS 5811 Built-in Dishwasher
Lg dishwasher part unknown
I was thinking about replacing motor on dishwasher and there was a small spring that went over shaft of motor on bottom side. It was bent and worn and was curious if you've seen it and whats it for? I am getting a E1 code and there are no leaks so im assuming its something to do with the motor. The unit fills with water then you hear the motor cycle on a few times before kicking up the E1 code. What do you think?
Thanks,
Chaz
  • 4 more comments
  • Chaz G
    Chaz G Dec 12, 2008
    I wish i knew, i got it at a garage sale. The model number is lds 5811st but the tag is missing off the machine. I have no idea how old it is or what the serial number is. Thanks for your help.
  • Chaz G
    Chaz G Dec 13, 2008
    Yes it must be older model b/c i pulled off door and saw the black tar stuff. No wires were burned through i insulated them to prevent any damage. I put the high loop in the drain hose which fixed the errors. I get no error codes now when running the unit but its like its not really washing. The spring i found was when removing the motor from bottom of unit, it was just sitting on shaft of motor.I will try to post picture later today. The unit is not washing though, you hear the motor cycle on 3 to4 times before it can begin its cycle. Sounds like its not getting enough water once it does start it makes a low growling sound but it doesnt sound mechanical. To me it seems like there is a air/water problem but i guess could be motor. Any more advice would be great!
  • Chaz G
    Chaz G Dec 13, 2008
    I did not see any shavings or black stufff, but the way the motor is assembled its stamped shut and would require drilling to open it up and take alook. I think i can get motor for about 67 bucks online. I will go ahead and replace it and post back to let you know if fixed it.
    Thanks for all your prompt help.
    Chaz
  • Chaz G
    Chaz G Dec 13, 2008
    DO you happen to know the part number for the gasket thats on the door? I am getting a slow leak at each corner of the dishwasher. Front side.
    Thanks again.
    the model of dishwasher agian is lds5811st
  • Chaz G
    Chaz G Dec 18, 2008
    OKay need more advice, i replaced the motor and im still hearing the same noise as before, But this time im getting an E1 error. IM assuming it has to be the motor water seal leakage of sump assembly as stated in repair manual but not sure what gaskets to replace. There are a few within the sump assembly and all look pretty worn or thin.
    ANy help would be appreciated as im sinking more into this thing then its worth.
    Merry Christmas
    Chaz
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Please send me your full model and serial number, and aprox. date of install.
  • 48 Answers
Yes i guess it is an older model b/c i took of the front panel and saw the tar like stuff that heats up and burns the wires. I covered the wires that were sticky and starting to get stuck to the black mat with some insulating tape. I am now not getting any e1 or 1e errors. I put the high loop on the drain hose which fixed those errors. The motor spins freely by hand and the small spring which came off the shaft was after i took the motor out from the bottom. IT looked like it was just resting on the shaft. Not sure of its purpose or if it was there by mistake. The symptons now are the motor turns on like 3 to 4 cycles before it sounds like it gets enough water to go but then it doesnt really work. It will move the water around b/c i can hear it inside but it sounds like a air / water whirling noise is happening with the motor. Sort of like a low growling noise but it doesnt sound mechanical. Hard to explain, and im not sure if the motor is workign right or if its a water / air problem. Any more advise would be great. I can send you a pic of the spring thing that was on the motor if you want, guess i would need email dont see a way to post the picture here. Thanks for your help i look forard to hearing from you.
Chaz
Posted on Dec 13, 2008
  • 1,543 Answers
If you got this at a garage sale and it has no model / serial sticker on it, it means the customer most likely had several problems with the unit and got it replaced no charge, but the model / serial number had to be sent in "to verify that the product was scrapped". That being said, on to your problem:
IE would be an inlet error, and E1 would be an error code which usually indicates the water has left the tub too early, as if the drain hose did not have a high loop in it, allowing the water to leak out the drain during the wash cycle. The sensor on the motor sees the increased speed of the motor, due to loss of resistance because the impeller spins more freely when in air than water, increased RPM will thus give the E1 error.
So, that may be all it is, but the reason I asked for the serial number is that early production models used an insulating mastic inside the door which became soft and allowed the wiring to become embedded in it. This resulted in the insulation on the wiring dissolving and shorting out or opening up (breaking) some wire(s) inside the door. That would result in various error codes, depending on which wire(s) were affected.
Take the door apart and look to see if the wires are embedded in the insulation. The fix is technically to replace the stainless steel inner door panel with one that has the newer insulation type and replace the entire wiring harness. That's fine if your unit was under warranty, but for you, splice in new wires and put something in the door which will prevent the wires from again becoming embedded in the door's black insulating mastic.
It is unclear to me if the spring you are referring to was found on the very bottom of the motor (as if you look at it from underneath the dishwasher) or if it was found from the inside, when you removed parts and finally got down to the motor. (I assume if that is the case, you discovered that the end of the motor shaft has a left hand thread) I suspect your motor is still fine. Look for the door insulation problem or a break in a wire where the wires pass out the door at the bottom of the door.
I hope with all this info we can get a FixYa out of this problem. It would be nice if you can send a comment to let me know what you found and how things turned out. PS. It is very important to use a rinse aid to get acceptable drying from this dishwasher, and of course you should have soft water.
    Carl Schulzetenberg Dec 13, 2008
    Did you see any indication of black powder or dark filings or chips on the underside? That might indicate that it is one of the units which had motors which had problems with the adhesive used on the magnets and make noise due to that. Don't think you have a water / air problem, as that should give the E1 code. (motor RPM's higher than they should be) I think with the noise you indicate you may want to replace the motor after all.
    WMBuyer Model: LDS5811 WW, BB, ST; LDF7810 WW, BB, ST; LDF7811 WW,BB, ST LGE Model:LD-6090 WB, BB, TB; LD-6105 WB, BB, TB; LD-6100 WB, BB, TB Buyer Name:LGEUS Effective Date:1 JULY 2005Applicable Serial No: 407KWXXXXX -506KWXXXXX Subject: Door Gasket Design ImprovementOld type (3920DD3003A) New type (3920DD3005A) Production has been applied since July 2005.3. Improvement (See Gasket Cross Section views below.)8.7 mm9.7 mm1. Phenomenon: Water leakage from inner door.2. Reason: Misalignment of the door due to improper leveling or externalshock. Improved part has a new Part Number. (Old Part Number: 3920DD3003A New Part Number: 3920DD3005A)New type improves reliability.※When servicing, be sure to verify the new part number because theshapes are similar and may be confused.※The old parts (3920DD3003A)should be scrapped.
    The above is cut and paste from a LG service bulletin. Motor is part number 4681ED1004A and $67 would be a great price if it is a new, unused part.
My lgis making a horrible noise and is now shoeing an e1 code dishwasher
The LG does suffer from "poor quality" motor that causes this type of noise. The main motor and pump assembly is common to give this type of problem. The pump seal leaks a small amount of water that gets onto the front bearing and causes a "grinding = humming" noise. This can be easly replaced once you have the bottom off and dishwasher on its door. The motoe has 1 screw in the back holding the motor to the bottom and two rubber seals for the water pump in/out into the washer. Just pull and move motor and pump assmbly and it comes free. Replace with a new motor and pump assembly...
Nov 18, 2011 | LG LDF6810ST Stainless Steel Built-in...
My lg dishwasher is leaving food particles on glasses and things on the top rack?
Check for blockage of the spray arm holes. If they are clear, replace the VIRO motor. It is a small motor next to the main wash motor, which turns a cam, directing water to the bottom, then the top spray arms. (usually, changes position every 2 minutes or so) You will need to remove the dishwasher from the cabinet to replace the VIRO motor.
Mar 06, 2011 | LG LDS4821 24 in. Built-in Dishwasher
My dishwasher has a LE error, which I think is a motor overload. Is there a reset switch for the motor?
There is not a reset switch.
First, check to see if there is any obstruction preventing the motor shaft from turning. You will have to remove the lower spary arm and sump cover. The round white impeller should be able to be turned by hand. To remove that, the phillips head screw in the center of it has a left hand thread, so needs to be turned clockwise to remove. Then, you will be able to get further down, to the metal cutter bar which may have a twist tie dental floss wraped around it. If all is fine there, and motor shaft turns by hand, you probably have a bad motor. (permanent magnets in motor can come loose, chip, crack, or the internal Hall sensor can be bad. To replace it, the dishwasher has to be laid on it's side so you can easily change it from the bottom side now.
Oct 03, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Noise during draining
to get to the motor or the pump you NEED to un install the dishwasher and flip it on its side or back and remove the botom cover.from there you will see whats up.
Aug 07, 2009 | LG LDF6810ST Stainless Steel Built-in...
Lg 5811 built-in LE code flashing checked wiring behind dr seemed ok
If you have separated the door panels and confirmed that none of the wiring is embedded in the insulation mastic, your next step is to take the covers off the sump area in the bottom of the dishwasher to see if anything (like dental floss or twist ties) is wrapped around the motor shaft. (note: the cutter blade on the end of the motor shaft is held on with a screw that has a left hand thread) If all was clear, replace the motor. To replace motor, pull dishwasher out of cabinet and lay on its side for easy replacement from this point.
Mar 01, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Lg dishwasher lds 5811st E1 error code
Hi Chaz,
The impeller breaks on the motor shaft. The motor still turns, but the impeller doesn't, so it doesn't pump water. Because the machine senses there is no water pressure from the pump, it shuts down & displays E1 (it thinks there's a water leak, due to no pressure)
Unfortunately the motor/impeller is only available as a complete assembly
Hope this helps
Col
Dec 11, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
E1 error on LG dishwasher
As per my email reply chazmano5, the problem is likely to be the water pump/motor assy.
They have a very common fault of the impeller breaking on the motor shaft. The motor still spins, but the impeller doesn't, so there is no water being pumped.
The machine senses there is no water pressure and shuts down, displaying E1 (eg: it thinks no water pressure means there must be a water leak) Unfortunately the motor/impeller is only available as a complete assembly.
Dec 09, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore elite dishwasher making loud buzzing sound when washing
I had the same problem with by Kemore Ultrawash after two years. The motor bearing went bad because the seal went out and dish water got to the bearing. If you are handy, this motor comes out after taking the dishwasher out. I was surprised how easily the motor came apart from the dishwasher, a good design. The motor has three screws that holds it together, I took them out and took the motor apart.
I took the old beaing off the shaft with a grinder, careful not to groove the motor shaft. I did, but just put some high temp silicone caulk in the groove before I put the new bearing on the shaft. I bought a new bearing on the internet, it is a 22mm x 8mm x 7mm. I bought one that went in a small engine, a quality one. I placed it on the shaft, put the motor back together and put the dishwasher back together. It has run quiet and great for many weeks now. I expect the dishwasher may last many years now, because the bearing I took out was a cheap aftermarket one, and the new one is vastly superior in quality.
Good luck and fire away with any questions. I love this dishwasher and am glad I could fix it for 19$ and some of my time.
Oct 08, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
DETERGENT DISPENSER
Hi the plates and bowels should face into the center of the dishwasher, the spray arm spins at the top and bottom from and sprays outward, check that you are using the soap dispenser and not the rince agent cups, also check to make sure it will spring open , ifall that is good then you may have a bad wax motor or a loose conection. at the wax motor. let me know
Aug 30, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
624 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
