Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon MP160 feeds only on left, probably dust, can i fix it myself?
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose...
If this fails then there hardware problem and its rollers failure in printer .....
Good luck...
Posted on Dec 12, 2008
Why MP160 printer can not pull the paper? how to fix?
Look to the pickup roller in the feed tray - is it covered in paper dust or other particles? Also look down into the paper path for obstructions.
Sep 24, 2011 | Canon PIXMA MP150 All-In-One InkJet...
The paper will not feed on the left side
Every time I see these I find pens, candy, clips, other objects have fallen down the back where the paper goes. One lady picked up her printer, turned it upside down and shook it and a bic pen fell out, It worked fine after that.
Nov 05, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp780 auto feed does not print
You probably need a new printhead, but that problem cann also be caused by the purge or cleaning station not working properly. If you do a cleaning cycle with no carts. and the little pads in the printhead come back with no ink on them then the purge is working and you need a new printhead.
Aug 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Jul 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Mp160 won't feed or sometimes will on left only, rollers r moving
I had a screw fall into my paper feed area before and didn't discover it till I tilted the printer on it's side. Could be a small foreign object in there somewhere. Tip it over and listen for loose stuff.
Dec 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
My pixma mp 150 keeps feeding to the right only
its the common problem of dust getting blocked in the gears of the left side which pulls the paper.just get your printer serviced to avoid further damage.
Dec 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Feeds multiple sheets of paper at once
This usually happens when "paper dust" builds up on the take in rollers. Clean the rollers with cotton and alcohol.
Sep 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
