Question about Toshiba 57H83 TV
I have a Sanyo Model DS13630 that I can not get any sound.
The picture is perfect and when I disconnect it from cable I hear the static load and clear - so the problem doesn't seem like it should be that speakers are blown...
  • Anonymous Jan 25, 2009
    Volume adjustment works as do the speakers because I can increase and decrease static sound. Appears to be in the audio separation circuitry but I have no idea of the where or what since I haven't any schematics. Any and all help appreciated in advance.
  • Anonymous Feb 05, 2009
    i have the same problem have you figured out how to fix it?
2 Suggested Answers
  • 75025 Answers
SOURCE: my 57h81 only sound is subwoofer
Check and make sure that the speakers are good. If speakers are good, suspect the power amplifier output seciton of the device.
Posted on Feb 05, 2012
Why am I getting the HDMI Error. Unable to display video(H15005 - HDCP link intergrity check failed?
The hdmi outputs on the uverse receivers are garbage, I recomend using them. Go to Walmart and buy a component cable install it and never worry about the hdmi error again.
May 29, 2014 | AT&T UVerse
Problem with HL-R6167W green vertical lines
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
May 29, 2009 | Samsung HL-R6167W 61" HDTV
Sanyo clt1554 has sound no picture.
I have a Sanyo CLT1554 (2 1/2 years old). Has perfect sound but no picture. The picture will come after several times turning it off/on and pressing the Reset button. It is very anoing to do this evey time. PLEASE HELP
Dec 15, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Tv in video mode
sanyo model: AVM-21 MB
problem: during tv mode the reception will loss and back
in turn to blue color then back to channel frequency!
at video the picture is okay but ther is no audio!
can you please suggest me how to solve this problem
can you send this to my email add. thank you and more power!
Jul 21, 2008 | Sanyo AVM-3259S TV
No volume
Feb 07, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Sanyo tv
Try to put DVD conection to your tv if it works normal no problem to your tv, but if sound dosnt work your tv has audio input problem maybe looseboard, or maybe you check the setting for audio.
Oct 03, 2007 | Sanyo DS13204 TV
No more picture and sound
Tv was showing perfect picture now it's snow solution 1 please check antena wire & its socket. 2 check for dust where wire is connected. 3 loose contact or print break near tuner. 4 tuner defective.
Sep 15, 2007 | Sanyo DS27930 27" TV
Sanyo DS19730 TV No Sound
Number 1 If the Sound is Ok,(CLEAR)For 1 min,Then the First thing I would be Checking Is the Audio Output for Ringbreaks around the Conns,If you have Jacks that say audio out on the Back Plug it into to a Input of a Stero and see If that works
Jul 18, 2007 | Sanyo DS19330 19" TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Toshiba 57H83 TV Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
