Question about Maytag Atlantis MAV6000 Top Load Washer
Agitator is too tight, does not move freely
I removed plastic agitator and the drum is still hard to turn?
    President:
  • 373 Answers
I can give you the possibilities for this problem.the problem can be solved by making a check on the drive belt,motor coupler,the motor and the pulley.the component location can be easily obtained from the manual. also Inspect under the washer for soot (clutch).
Posted on Dec 12, 2008
GE washer WNSB9080B only allows me to run "Drain and Spin", no other cycle. It wounds like there is still water inside when I move the drum around.
In top loading washing machines, the agitator is responsible for moving the clothes through the water and detergent and is driven by the output shaft of the transmission. The output shaft is normally splined and the center of the plastic agitator will have a matching spline to ensure a tight fit. Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Jul 18, 2016 | GE Washing Machines
Tip
Noise from Whirlpool/Kenmore washing machines / agitator not turning
Many toploading Whirlpool (and Kenmore -- they're made by Whirlpool) washing machines have a ratcheting agitator. The agitator moves only one direction instead of back and forth. There are small pieces (called agitator dogs) that allow this to happen. However, since they are mad out of rather soft plastic, they tend to wear out. The result is a ratcheting or growling noise during agitation (wash cycle) Luckily, they are reasonably cheap (usually under $20) and relatively easy to fix. Try to turn the agitator by hand. It should turn freely one direction and not the other. If it goes both ways freely or clicks and slips one way, you need new agitator dogs. Pull the cap off of the top of the agitator (there are usually two tabs on the side that must be depressed to do this) Remove the bolt in the center of the agitator. Pull out the plastic plate that is on top of the dogs (again, you may have to move two tabs to pull this out.) You should see dogs that look just like the new ones except with no teeth on them. Pull the old ones out and put the new ones in the same way. Reassembly is the same as disassembly except in reverse. It should be quieter and wash better now, as the agitator was barely turning before, if at all.
on Dec 02, 2009 | Washing Machines
Fisher and Paykel ECS Washing machine agitator slipping?
There are "dogs" under tops of some agitators. Easy to repair. ID them and pull up washing machine parts at Amazon. Dogs are by themselves(3 hard plastic gadgets) but better to buy the whole thing that hold the dogs. Usually under $10.00.
Apr 25, 2017 | Fisher Washing Machines
GE washer model WJRE555OH1WW - agitator free-wheels.
First make sure the inner part of the agitator is not brocken.
Remove the soap cap from the top of the agitator and with a torch, look down into the shaft. There is normally a nut which secures the agitator to the gearbox shaft. If the plastic around the nut is broken then the agitator moves freely.
There may not be a problem with your gear box, then and relatively cheap to replace agitator.
goodluck.
Ash
Oct 22, 2009 | GE Washing Machines
Agitator spins freely as if not connected
Check to see of bolt is tight that holds agitator in place
Oct 02, 2009 | General Electric WHDSR209DWW Top Load...
The plastic drum just keeps spinning freely during the wash cycle
Yes! to let you know that this is NORMAL when the washer agitates, due to the "Westinghouse" designed transmission, which in turn is called the "Franklin" design.When the agitator returns back stroke the washtub "indexes" before the agitator strokes forward. Thus moving the load around through the water while being moved back and forth.
Plus! to let you know that since the washer does NOT have "brakes" to stop the washbasket and hold the basket this design allowes the "indexing". This is one of the main reasons your washer has a safety lid interlocking device on it to lock the lid when it spins, because the washer has no brakes to stop the machine if the lid is opened during a spin cycle.
Sep 13, 2009 | Frigidaire FWS833A Top Load Washer
The agitator will not turn
please be more specific. Do you mean that the drum turns but the agitator in the center does not trun at all? Does it turn freely by hand in both directions? Does it not 'rachet' as the drum cycles? The problem may likely be the agitator dogs. These little plastic pieces are found by taking the agitator apart (cap, holding bolt, catch burrs, etc). They are designed to allow the agitator to rotate in one direction only, thus forcing your clothes in a downward spiral in the center of the washer. The parts are fairly inexpensive ( a couple of dollars) if ordered online. The hard part is getting to them.
Aug 21, 2009 | GE Washing Machines
I am unable to remove the agitator from my Kelvinator K605 washin
 Before removing the agitator, unplug the washer to avoid an electrical shock hazard.
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
he agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
read more about the agitator removal in the next comment.
Jan 30, 2009 | Washing Machines
Washer will not agitate, took belts off and it will only spin one way.
Only one direction seems fine. On some machines there is a solinoid connected to a lever that either disengages or engages the drum brake to keep the drum from rotating during agitation. Some units reverse the motor direction when agitating and spinning. (one direction for spin the opposite for agitation. Most generally when the motor works in only one direction, say it spins fine but not agitating the culpret is the control dial. There are several combinations of electrical connections that must all make to go from one cycle to the next. On some other models there is a plastic cog that is moved by the solinoid to make the change. Without other info such as make and model, I can't really be sure how to tell you to diagnose the problem..The main thing is one direction is probably right on the turn question.
Feb 03, 2008 | Washing Machines
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
