Question about Goodman CLQ36AR49 Air Conditioner
GOODMAN ARUF3642 I NEED TO KNOW SIZE OF FILTER USED IN THIS UNIT
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Buy a cut to fit filter (mohair type, blue) if they are hard to find or go to an a.c.supply house and give them your size. koolbreezes74401@yahoo.com
Posted on Jun 09, 2008
  • 944 Answers
These guys list the actual sizes of a good selection of goodman filters - just measure the old one or the space where it should be and match it to the right filter(should be a fairly tight fit). http://www.filters-now.com/products/dgb.html#skipmenu and this site describes what the different filter types available are http://www.oxyclean.com/goodman.html Hope this helps :)
Posted on Mar 07, 2007
What size plenum do I need for a Goodman 10kw electric furnace
There is no right answer for that. The bigger the better, ideally 4 ft long by the dimensions of your unit supply.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 08, 2018 | Goodman Heating & Cooling
Trouble locating the air filter in the Goodman heating unit. CAPF036A2A
it will behind return air grille either in the room, ceiling, & i have seen them in attic in return plenum.
Feb 10, 2015 | Goodman Heating & Cooling
I need to know the proper piston size for this unit when it came with a 63 on one peice and a 68 on another I used the 63 and the unit doesn't seem to be working properly please advise
use the size that came with the outside condenser. if the outdoor unit is more than 6,000 btu's than the indoor unit, it will not cool properly. you can always mate a outdoor unit to a indoor coil that in 12,000 btu's or less in size.
Oct 10, 2010 | Goodman CKL42AR42 Air Conditioner
Thermostat wiring diagram for ARUF3642
There should be a wiring diagram inside one of the covers on your air handler. Here is a link to a site that I believe is for your model:
http://www.shop.thefurnaceoutlet.com/media/ARUFInstall.pdf
Jul 25, 2010 | Goodman Furnace Draft Inducer Blower ...
How to change the filter ?
Your filter is in one of two places.
Either its in a filter grille or its at the furnace/air handler itself. If its in the grille, simply remove and replace.
If its in the unit, it will be at one far end of the unit opposite where the electrical connections are. It's uncommon for Goodman to be filtered at the unit as they do not have an independent filter access panel but I have seen it.
If its not in either of these locations, you either do not have a filter installed or your installing contractor has installed a filter box somewhere that will need to be located.
Hope this helps.
Jan 10, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman CACF048B2A Air. need to know the location of the replacement filter
The disposable filter is always in the return air of an a/c unit. If your unit has a furnace attached in an upright position then the filter is under the furance blower wheel. You will have to remove the bottom access panel to see and replace it. If your unit is horizontally installed in an attic then the filter will most likely be up in that return air duct or possibly in the return air grille possibly mounted in a hallway or someplace like that.
May 30, 2009 | Goodman CACF048B2A Air Conditioner
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
I need to know the type or size(tons) air handler
3 and a half ton S3642C6AA
42 is the unit size then you divide that number by 12
May 05, 2009 | Heating & Cooling
Need to Know Where to Change the Furnace Filter
On the bottom of the indoor unit should be a cover or tray. Sometimes a large grill inside the house, close to the unit is where they are placed. Good luck
Apr 23, 2009 | Goodman Heating & Cooling
GOODMAN # ARUFO49 AIR HANDLER
MOST ALL GOODMAN ( UP TO 3 TONS)INTERNAL FILTERS ARE 22" x 22" X 1". YOU CAN GET THEM ON LINE AT www.filtera.com. ALWAYS TAKE A TAPE RULE AND OPEN THE BOTTOM FILTER DOOR AND MEASURE THE FILTER RACK. MAKE SURE YOU DO NOT HAVE A RETURN-AIR FILTER-GRILLE. LARGE WHOLE -HOUSE RETURN AIR VENT NEAR OR AT YOUR FURNACE, A/C AIR HANDLELER. Joe_Rex New Member of FixYA Retired HVAC&R contractor 45+ years exp.
Mar 07, 2007 | Goodman CLQ48AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
427 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Dennis Boxerman
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
