Question about RCA R52WM24 52" HDTV Projection Television
No red at all in the screen. Where are the fuses located?
All of a sudden there was no red. I would like to know how to get at the fuses if that is the problem and where can I purchase the fuse.
  • 905 Answers
Look for fuses that look like little capacitors near the flyback transformer if that is not the problem then resistors and the convergence IC's will need to be checked and or replaced
these parts can be purchased at any electronic parts supply store
Posted on Dec 12, 2008
110v outlet on my 2010 traverse and blew a fuse or something tv screen doesn't work now and sudden it now says on the dash that park assist is off The camera is working which fuse controls all of that
25 amp PWR OUTLET fuse , location - under hood fuse box. This fuse supply's power to the Accessory AC/DC power control module .
MSM 10amp fuse location instrument panel fuse box . This power's the object alarm module .
Nov 30, 2017 | Cars & Trucks
Anyone know why my Clock and Radio have no power?
blown fuse check under the hood or under the dash check your manual to find the exact locations
Jun 16, 2015 | 1999 Mitsubishi Montero Sport
Screen image
Go to menu then setup look for convergence if it is not Listed then you have an open fuse FL231 it is located on right side of FBT flyback transfomer there is 3 in a roll small brown rectrangler looking caps but they are fuses the one in the middle is BAD.This is a $ 225.00 repair job.if done by TV shop.
Aug 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pioneer SD-582HD5 - screen went black, no sound, however the power switch - red light on the front panel is still on
There are actually two fuses on the smps F201 (6.3a) & F202 (5a) if either or both of these are open the problem is not likely the fuse. What I try and tell customers is that a fuse being open is merely a symptom, never the cause.
This particular unit is plagued with poor solder connections which case the voltages to flutter violently and the symptoms you're experiencing... You would be wise to remove the power supply and replace it or have it rebuilt. There are a number of companies that specialize in rebuilding boards of this nature or any qualified shop could do it if they had the whole Tv, since they probably don't have a jig special for that unit.
In summary, check the two fuses above and just be prepared that replacing them won'y solve the problem and most likely just open the new fuses in a short time.
Bill
Premuim Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Sep 13, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Red Led Flashing
If you haven't already found a solution to this problem, it is more than likely a failed fuse. If you are comfortable with the high-voltage electronics in your TV and are handy with a soldering iron, you can attempt to locate and repair the fuse(s) yourself. However, the fuse is more than likely failing because of an additional problem. It all depends on which fuse failed. Can you get back to me?
Dec 30, 2007 | Toshiba 57HX81 57" Rear Projection...
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Mitsubishi VS-60705
1. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12596" TO ENTER THE CONV MISC. MENU THEN "8970" TO RESET.
Aug 21, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Red Curved line
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Sep 09, 2006 | Hitachi 43FWX20B 43" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
