Question about All-Pro Forced Air Kerosene Space Heater SPC-K75
Reddy heater 70,000 with factory thermostat will run a few
Seconds with top on turn thermo off then on will start with a poof of smoke and and quit within a few seconds. Take top off will run great.any ideas?
  • 232 Answers
Set the pump pressure. If correct check the nozzle. Desa recommends annual replacement.
A worn nozzle creates a spray pattern, where a good nozzle creates a fog. With a coarse spray pattern poor combustion results in an off color flame, . The photocell doesn’t like the color, sends a signal to the computer which shuts everything down. That’s the job of the electronics.
Posted on Dec 12, 2008
115,000 btu reddy heater, 5 hrs used in sprayfoam-grinding environment. stopped working. when plugged in, only hums for a few seconds, then stops. how can i fix that?
First, remove the top cover. Inspect for a varmint nest. If clear, manually spin the fan. If it does not you either have a broken rotor that is binding or you have a bad bearing.
If it spins freely, apply power- see if the motor runs with the top cover removed.
If YES, replace the top cover. Its possible that the top is binding the fan.
If NO, the start capacitor is defective. The cap on R115 is internal and is not servicable.
Reading material about a hummer
Nov 04, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Heater runs but smells like exhaust fumes then when running stops for split second then keeps going after a big poof of smoak
Replace the spark plug first. The fuel may also be contaminated. If you can stand the
smoke go for it.
Feb 03, 2011 | Reddy Heater 60,000 BTU Kerosene...
Reddy Heater-50,000 won't fire, fan comes on for few seconds than shuts off
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
Sep 17, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have a Reddy Heater 70,000BTU without a thermostat. It will flare off and within a few seconds the fire goes out and then the it trips out. After a few tries it won't even flare off. What might be wrong?
hello. Your reddy heater is dirty and needs a good cleaning. Also, here are a few other possible reasons why it won't operate properly. Pressure not adjusted to 5.1 psi, dirty outlet filter, clogged inlet filter, bad or dirty photo cell, defective reset switch, pump going bad, dirty injector nozzle, dirty fuel filter, contaminated fuel. Check yours out and do what you can to address each area of concern. Regards, Joe
Jan 21, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Kerosene reddy heater flame is intermitent
Heater had a cracked fuel line that was not visiable on original inspection.
Jan 25, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
70,000 BTU Reddy heater - runs - but it puffs smoke
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 28, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 110btu kerosene starts and shuts off?
I would say the thermostat is bad after reading your problem over several times. There is no reason to suspect a wiring problem, and I strongly suggest you don't bypass anything! A fire or explosion could result. Replace the thermostat as a probable cause.
Ray
Dec 08, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
All-Pro Forced Air Kerosene Space Heater SPC-K75 Logo
117 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
