1) test for some wires connector loose inside of control board
2) test for fuse or c.breaker contacts loose, or corrosion, clean unplugged the machine.+test the power cord for open
3) runt the diagnostic test, read you instruction manual for help.
4)see if the water supply is open this cause not start the washer
5)motor overheating, the motor had been designed for to run until complete the cycle, wait by 40 minutes for to cool the motor. and try the cycle again.
6) Lid switch mus be close very well , test the switch for open or defective.
SOURCE: Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
SOURCE: unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Testimonial: "this is very helpful, Allthough I am not capable of carrying out this work I do at least know what the repair guy may say. thanks."
SOURCE: Ariston Dishwasher LI 675 DUO
1) Ensure the dishwasher is turned off.
2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher)
3) Pour powder indo the dishwasher
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
5) Press the on/power button on the dishwasher, so that it now turned on (a light will display)
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position
SOURCE: my zanussi 1400xc washing machine
unplug for 40 minutes to reset the ECU. If still doing the same - replace the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
