Question about AcerPower Se PC Desktop
Power Problems :S
Hi, I recently kicked the power cord out of the back of My AcerPower ST Tower (model is not listed on this site, but I think this could be a multipurpose problem). When I plugged it back in, I press the power button and the power light goes on for half a second, then turns off. The system does not start up and there are no more signs of activity from the tower. I am worried because I forgot to turn the power source off the wall before I plugged the power cable back in, I just plugged it back in straight away. I have tried with different cables and power outlets. Does this sound like there is now a problem with the tower's circuitry? Is there anything else I can try? Thanks, any help would be greatly appreciated.
    Scholar:
  • 125 Answers
Symptoms suggest failed Power Supply. May be failing as more of the computer kicks in and the load goes up. May read fine on multimeter if tested with no load, but still be fried.
Posted on Mar 07, 2007
  • Gecko Smooth
    Gecko Smooth Mar 07, 2007
    If you jerked the machine hard, it would pay to check nothing has shaken loose on the motherboard too.
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Proton
Oct 13, 2012 | Computers & Internet
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Hello, i have a problem with my PC Model: Acer Aspire M7200 (Desktop Computer.) . I left it running over night and this moring i woke up and the power button was flashing blue, and dosnt turn on. I dont...
    Hi gatisd2
    PLEASE RATE MY ANSWER IF YOU FOUND IT HELPFUL
    I think its gone into power save mode my does that i pull out my power cord from the tower wait 30 seconds then plug it back in....See if that helps (TURN OFF ALL POWER SUPPLY FIRST)
    Jan 30, 2011 | Acer Computers & Internet
    My computer tower will not turn on. I tried the steps listed on the HP web site, disconnected the power cord, and all cords connected to tower and held power button for 5 seconds, then plugged power cord...
    black screen , totally is here,
    one page covers this.
    http://pcdied.com/black-screen.html
    test one do all Desktop fans run
    if not the PSU is bad. 99% we can 1% if PSU is ok.
    May 06, 2017 | HP Pavilion a1630n PC Desktop
    IWe have replaced the Acer F1 pc power supply with a new one, still no start up power. Power supply does not start, no fan spinning?
    Try using a differrent power cable, you could use the cable which goes to the monitor. If that works, then you need to just get a replacement power cable (could be US 3 PIN Spec).
    If that doesn't work, then the power supply of the computer tower needs to be replaced.
    Oct 25, 2010 | AcerPower F1 PC Desktop
    There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to ... Hi, i have a dell Optiplex 780 running windows xp, the computer button is just...
    If you are referring to the green light on the system tower and is blinking the problem could be the system is in stand by mode.
    Turn off the computer by pressing on the power button on the system tower for 10 seconds.
    Disconnect the black power cord at the back of the system tower and then again press the power button on the tower for 10 seconds. There would be no activity on the tower when you do this.
    Reconnect the power cord and then power on the computer to see if the issue is resolved.
    Thanks for using Fixya
    Proton
    Aug 30, 2010 | Dell XPS 200 PC Desktop
    PC won't power up
    Hi! Try to check if there is any power light or any lights on the machine whenever you try to turn it on, also, try to directly connect the power cable directly to the wall outlet.If you have a spare power cable try to use it.If you are getting the same result, try to unplug the power cable at the back of the computer, press and hold the power button for 10 secs and after that plug the power cable back in and then try to press the power button.Check for indicators if the system is getting power for example, check lights, check if the fan is spinning at the back, check if the dvd/cd drive will open or check if the tower is emitting any sound.If still the same and still no light coming from the tower then it might be a issue with either the power supply or the motherboard, you can call your manufacturer and have the machine serviced if its still under warranty.Hope this helps...
    May 20, 2010 | AcerPower FH (APFH-EP9150C) PC Desktop
    Acerpower SV PC will Not turn off
    More information would help to resolve this issue.
    Are you shutting down by selecting Start and shutdown or have you tried pushing the power button on push (not holding the power button)?
    Try this:
    Press and hold the power button in solidly for about 10 seconds. If it shuts down before you get to 10 just let off the power button. This should work, but may not solve the problem.
    If you reboot it and still can not shut down from Windows, hold power button until it shuts down, unplug the power cord and disconnect everything from the computer other than the keyboard, mouse and monitor. With the power plug still unplugged, hold the power button in for about 15 seconds (this resets the power supply and can clear a corrupt BIOS).
    Reconnect power and after booting, see if you can shut down from Windows.
    If still no go, click Start, Programs, Accessories, System tools and select System Restore.
    Follow the prompts and select a bold date back to a time before you had problems shutting down. That should do the trick.
    Let me know if you get it fixed or if you need more advice.
    Honest1abe
    Jan 02, 2009 | AcerPower SV PC Desktop
    ACER power 1000 has no power at all
    change the power supply, if still nothing then motherboard might be gone
    Dec 31, 2008 | AcerPower 1000 (AP1000EA380M) PC Desktop
    Tower gets no power
    90% of the time this symptom indicates a bad power supply.
    If a generic system and in some name brand systems, the part is quite cheap (about $40) + labor.
    In rare cases, the power switch could be bad.
    Oct 25, 2008 | Power Up (TC3J-4048)
    AcerPower Se PC Desktop Logo
    54 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
