Question about Gateway Media Center 610XL PC Desktop
Won't boot. Power light on, No Video Signal message
OK Experts, I like the 610XL media center, and I want to fix this myself.
When I press the on/off: The green power light comes on, and stays on. I can hear the hard disk spin up, and the blue disk read light comes on. I can hear the disk reading - but for a very short time - 3 seconds or so. THe disk reading stops, the blue light goes off, the screen shows a "No Video Signal" message that appears for about 2 seconds than goes away. The green power light stays on, the fan stays on, and it's throwing a normal amount of heat.
I'm thinking that the harddisk has failed? This might be optimistic since I think I can replace that with no trouble :)
cheers,
CArchibald
  • gatewayblues Feb 26, 2009
    My unit will turn on (sometimes). Then a loud crack and its dead...no power.
    Sometimes I get no pwer at all. Sometimes just a blue light. Sometimes just the green but nopthing else. except the mdem light in the back is on so its getting some power. I'll let it sit and sometimes it works fine. Ive read about the PSU issues . For around 30 bucks I can try and put a used unit in. Just not sure if thats the issue.
    Problem Solver:
  • 8 Answers
It's also possible that your operating system has become corrupted. See if there is enough time to boot into safe mode, or choose a boot option to go into the recovery partition.
Have you made any recent hardware or software modifications?
Posted on Dec 12, 2008
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
It doesnt boot up at all , good power,but nothing past the power cord.
Most likely the power supply inside the unit is bad. Try replacing the internal powersupply.If possibe.
Jun 09, 2010 | Gateway Media Center 610XL (610XLMDIA) PC...
No signal cable message
No punctuation, no sentence, no question; no answer!
Feb 16, 2010 | Gateway Media Center 610XL PC Desktop
Gateway 610 Media Center
I would then suspect the monitor.
Sounds like the video card is working.
Try another monitor to see for sure.
Sep 09, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
I have no video output on my desktop, a gateway media center GT5034. all the lights blink, showing haddrive activity. I have tried to different monitor and another video card.
Try removing your RAM cards leaving only 1 at a time in a try to boot until you figure out which RAM card is causing it. Sometimes bad RAM can cause issues like this.
If that doesn't work, try unplugging the power from the tower, and then open up the case and remove the CMOS battery which is on the main board (motherboard). It's a little flat round battery. Leave it out for 30 seconds or so, then put it back in, close your case, and try to boot up. What this does is clears the CMOS so it will be set to default bios settings. After you do this, it may show a picture on the screen, and then you can go back into your bios settings and set anything you need to back up. Or you can just load "Optimized Defaults" and then press F10 to save the settings and reboot.
I hope this helps. If not, let me know and I'd be glad to further assist you.
Best Regards,
James
Jul 21, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
Some of the files needed to play video are missing or corrupt
When that happens you usually need to backup your data, and reinstall the system to fix Windows corrupted files.
Try first doing a system restore to the most recent date before you started having the problem. If system files are damaged this will not help.
May 16, 2009 | Microsoft Windows XP Media Center Edition...
I have a gateway media center 610xl that has no power.
if you know on how to replace the power supply then do it, if not proceed to bring the computer. or if you have friends can do this, then much better.
Mar 15, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
Non system message
Your boot sequence is probably not set to boot from the Hard drive first. Remove any floppy disks/CD's from their drives and try to boot it.
If you are still getting the message then you have files that are corrupt on your hard drive.
Jan 26, 2009 | Gateway Media Center 610XL PC Desktop
How do I install a power supply in a gateway 610xl computer?
REMOVE THE CASE AND UNPLUG ALL.THERE SHOULD BE 4 SCREWS HOLDING IT IN PLACE REMOVE THEM.REINSTALL NEW IN REVERSE.RICHARDM69
Nov 26, 2008 | Gateway Media Center 610XL PC Desktop
Start up problem
I've checked your media center model on the net and it appears to be a known BIOS problem. Keep in mind that this is most likely video card or motherboard failure. But we can try resetting it Try booting into the BIOS using the F10 key and then pressing F12 and pressing y. The system should reboot with the default BIOS settings. If there is any change you likely have a good chance at fixing it. Please post your results.
Jun 15, 2008 | HP Media Center m7060n PC Desktop
Gateway Media Center 610XL PC Desktop Logo
250 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
