Question about Toshiba Satellite A100-S8111TD Notebook
My laptop (Toshiba Satellite A100) won't power on. It generally has temperature issues, either overheating or not turning on due to excessively cold temperatures. However, this time the laptop has been in room temperature for over 2 hours. It was working fine when I last had it on, which was earlier today.
  • 22 Answers
Okay, sorry to disappoint you, but you may have a faulty motherboard. You have a nVidia GeForce Go 7600 video card, which are prone to heat issues, resulting in failure. Dell and HP have been recalling laptops with the 7 and 8 series GPUs.
Call up Toshiba, and even if you are out of warrenty, tell them that the video card on your motherboard is bad. Educate yourself here before calling though:
http://www.insidetech.com/news/articles/2748-dell-hp-lists-reveal-defective-nvidia-mobile-gpus
http://www.theinquirer.net/inquirer/news/186/1010186/dell-models-defective-nvidia
Make sure they know that its a universal issue that they need to address themselves.
Posted on Dec 12, 2008
Toshiba satellite a100-153 running hot
Something is very wrong here. Does this occur when running on internal battery or only when plugged into the power adapter? At these temperatures the cooling fan should be running at full speed constantly until the temperatures fall to about 50 centigrade or lower. (dependant upon loading and CPU power consumption.) The laptop should automatically power down at the temperatures you are quoting!
Apr 08, 2014 | Amstron Toshiba Satellite A100-153 Laptop...
When i power my toshiba laptop how do i test my power inverter or back lite
The plastic frame in front of the LCD screen is the Display Bezel.
The screen Inverter is mounted at the bottom of the Screen Frame.
[The LCD screen is an assembly of layers. There is a metal frame resembling a picture frame; which keeps these layers in the factory set alignment; the Screen Frame ]
Therefore easy access. Just remove Display Bezel.
To test a screen Inverter requires a sensitive multimeter; read fairly expensive,
http://www.fonerbooks.com/test.htm
Due to the above, ease of access to replace, and generally low cost; the screen Inverter is just replaced.
Then on to the Backlight if this doesn't repair the problem.
Which brings me to this;
Safety
https://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A100/
The Toshiba Satellite A100-S8111TD Notebook PC, uses a single CCFL for a Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to it's larger 'cousins' used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
This means it is Highly breakable. Costs more in money to just replace the entire LCD screen, (Which has the Backlight built-in),
but cheaper when you compare to life, and limb.
Jus sayin'.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Toshiba Satellite A100-S8111TD Notebook
Satellite L500 monitor is completely black. One can faintly see the welcome and password bars
Try to go to Toshiba Power Settings in the control panel and change the lcd brightness from there. If this won't work, this may be an LCD backlight issue and you would need to have a professional to change it for you. If it is under warranty, send it to toshiba for replacement.
Hope this helps.
May 30, 2011 | Toshiba Satellite A100-S8111TD Notebook
I need to replace my fan for my toshiba laptop, nad need to know how to disassemble the laptop to get to the fan.
Toshiba Portege A100 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A100/remove-systemboard-replace-fan-1.htm Toshiba Portege A600 or A605 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A600-A605/disassemble-laptop-1.htm Toshiba Portege M700 http://www.irisvista.com/tech/laptops/Toshiba-Portege-M700/take-apart-tablet-pc-1.htm Toshiba Qosimo F40 or F45 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-F40-F45/laptop-disassembly-1.htm Toshiba Qosimo G25 or G20 http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm Toshiba Qosimo X305 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm Toshiba Satellite 1955-S805 http://sites.google.com/site/electrochain/toshibafan Toshiba Satellite 2410 http://mardou.dyndns.org/Privat/homepage_cms.ns5/content/homepage_tutorials_toshiba_satellite_2410_-_luefter_tauschen.html?Open&lang= Toshiba Satellite A35extlink.png http://www.irisvista.com/tech/laptops/ToshibaA35/Satellite-A35-fixing-overheating.htm Toshiba Satellite A60extlink.png http://tech.icrontic.com/articles/clean_laptop_heatsink Toshiba Satellite A105extlink.png http://www.paulstravelpictures.com/Toshiba-Satellite-A105-Laptop-Overheating-Dust-Removal-Guide/index.html Toshiba Satellite P10extlink.png http://loblog.wordpress.com/2006/03/08/toshiba-p10-schaltet-sich-ab/ Toshiba Satellite P305Dextlink.png http://www.insidemylaptop.com/clean-cooling-fan-toshiba-satellite-p305d/ Toshiba Satellite X205extlink.png http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm List of a lot of pc fan repair guides:http://repair4laptop.org/notebook_fan.html
May 09, 2011 | Computers & Internet
Problem: A100 flashing Amber light but won't turn
Check your charger. It seems to indicate low batery and the charger may not work or the power socket has a faulty connection. Check for phisical damage in the power socket of you laptop.
Try to twist it or even push it in a bit while trying to switch on. Try also to remove the baterry and use the charger power supply only.
If nothing happens its very likely to be the charger.
Jul 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
I ahve a toshiba A100. It frequently freezers for
This can be due to malfunction of an application (virus/trojan horse), ensure cpu, memory utilization is not too high, check whether the cpu is overheated, try freeing up memory by unloading unwanted processes
Oct 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
My Toshiba m205 4806 shuts down spontaneously. The lap top feels warm but the fan is running. any suggestions?
The cpu get overheated and will shtdown to protect it. The fan continues to run until a CPU safe temperature is reached / sustained.
1. Use laptop on flat surface, not on pillow, carpet, bed, etc. that will restrict air flow. Using a can of compressed air, clear the air vents.
2. If the symptom continues, then the heat conductive paste between the cpu chip and the heatsink is no longer effective (hardened, too thin, etc.). Remove the heatsink and add thermal paste
($6 Radio Shack).
Sep 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100 LE4000 Turns Off Randomly
there must be still a problem with your current cooling system. try cleaning up your laptops fan. cpu gets heated up very easily even if you turned it off for a while. you can do this by unscrewing the parts, the inside must be pretty dusty or something. this also happened to me but from a different unit.
also, try checking for the latest bios driver for your laptop and to be sure, download it on toshiba site itself. because latest drivers for your bios also manages the control of your cpu fans.
if you could also get access to your systems cooling options in bios, try checking if your cpu's temperature are doing fine.
but i prefer you cleaning up the inside fans as well. hope this helps.
Feb 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
370 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
