Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
Smeg oven SE399X/5 - digital clock issue
Hi, the plastic part of the digital clock has 'dislodged' and is not covering the button holes properly. the buttons seem to be worn away and will not press in either. How do i get the front part of the oven off to re-seat the clock. Or how can i get the buttons to work. The oven is stuck on 'A' for automatic and will not turn on at all now since i had a power cut.....help!!!
I'm glad I'm not the only one either - in the end I bought new buttond from smeg service/parts centre on their website. I took apart the front of the oven and re-seated the clock. I pushed in the new buttons and now its all ok. My problem was that because the clock had mis-lodged the buttons were touching the metal at the front of the oven, and like you when the grill is on the metal gets too hot and melts all the buttons. So the clock has to be in exactly the right place or it will melt the buttons so much that they will not press in...what a bummer!!! :-)
Posted on Jun 15, 2007
I'm glad I'm not the only one with this issue. My husband had the grill on too high and melted the buttons, I thought they weren't going in because of that but we've got new buttons and they're working at one side of the clock and not the other. For the meantime, you can get a thin screwdriver, or something, and poke it through the holes where the buttons would go to substitue. That will get it working in the short term.
Posted on Jun 14, 2007
How do I set the clock/timer to make the oven work?
does it have a clock button , if so press it then use the +or- buttons to set the time then press clock again
Dec 06, 2015 | Ovens
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Smeg oven is "locked", needs unlocking or resetting
Use a flashlight and look into the hole from where you normally feel hot airflow. Locate the hook holding the door on the left side. Using a thin screwdriver or a knife gently push the hook to the left. Voila! The door is open and functions are back working normally. Also known as Error 4 interlock problem. This will depends on the model of the oven
Jan 30, 2010 | Smeg SE399X/5 Stainless Steel Electric...
Cant fix the clock to work without the timer
if you are having trouble setting the clock times etc this is probably down to a worn bit generator this is the knob you turn to set the time they get dirty when using oven or grill and wont operate properly,the clock will need changing im afraid as there no way to open the clock without destroying it.
hope this helps
Jul 09, 2009 | Neff B1421 Electric Single Oven
SMEG SA410X-S heat not coming on for fan forced cooking. The fan and light work, and the heat works fine for grilling.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Mar 18, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Thermador CMT21 clock and timer don't work
If you have the old analog clock, there is a new digital replacement kit that makes this oven look modern and give it more life
Mar 17, 2009 | Ovens
Smeg oven SA392EB cannot reset clock
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Oct 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
655 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
