Question about HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop
No power to a SR1420NX.
The machine was off when I went into the office this morning. No power issues on any of the other machines. Pushing the power button on the front does nothing.
There is a green LED on the back of the power supply just below where the power cord is plugged in. It blinks about 5 times a second with the power cord plugged in and about 2 times a second when unplugged. I assume that If I left it unplugged for a long time, it would stop all together.
Is the flashing LED an indicator of some kind? Do I need a new power supply? Or is this normal behavior of a healthy power supply?
  • 116 Answers
Power supply light on or flashes Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
  1. Disconnect everything from the computer, including the power cord.
  2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps. NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
  3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switch No power to a SR1420NX. - c00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
  4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
  5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it. NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
  6. Remove all attached devices except for keyboard, mouse, and monitor.
  7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
  8. Check the power switch:
    1. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
      • If the button sticks, it should be replaced or serviced.
      • If the power button does not stick and appears to be functioning, continue using these steps.
    2. With the power cord disconnected, remove the case or side panel.
    3. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
    4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboard c00517968.jpg
    5. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
Posted on Dec 12, 2008
I have a simpson EZI set 750 went to use this morning turned machine on nothing happened no lights on panel
Hello Barney - sorry about your washing machine and I can only offer you this link to some reviews of the machine. A couple of reviews down the page have links to Simpson representatives, who may be able to help you out with the issue. Take care. Kind regards,
Simpson EZIset 22S750L 22S750M
Mar 18, 2014 | Ariston Technologies AWD 121
My Maytag Performa washing machine will not stop filling with water and start the next cycle
you need to unplug it from the power when it does that to see if it stops filling. That will tell you if it is a valve issue or a problem with the controller
Feb 09, 2013 | Washing Machines
Hoover dyn8164d washing machine, when the last load washed I went to remove the clothes and there was a 'buzzing' coming from the top right area of the machine, I turned it off as usual, and t
Possible that the main power has failed , the power supply of the unit had packed up or there is a serious fault in the controller unit. You need to open the control panel unit to trace this case specially using a multimeter, check for the AC power to the unit and check for the DC to the circuit. If not the panel is a suspect.
Dec 31, 2012 | Hoover Washing Machines
Model 7210. pushing the power button no longer starts the machine
Your adapter went out or your power board where the button is located went out.Bad ram sometimes will cause this problem as well.
Jul 31, 2009 | Computers & Internet
Yellow power light on HP SR1420NX
For reasons yet to be determined, your computer is not talking to your monitor.
This could be the monitor cable came loose from the tower (this is our favorite, because it is such an easy repair), or something on the motherboard (that is, anything) that is not functioning and preventing your computer from starting.
Unplug the connecting cable, and plug it back in again, making sure that it is seated properly.
Do you hear any sounds besides the fans? You should be able to hear the faint clicking of a hard drive starting up also. If you hear this, the problem is not in the computer, but in the communication to the monitor.
Good luck
May 23, 2009 | HP Compaq Presario SR1420nx...
Breville Aroma style coffee machine in our office
did you try to set the time and then set bre time.  I have a coffee pot and microwave where both will not run unless the time is set.
May 04, 2009 | Coffee Makers & Espresso Machines
Xerox workcentre m20i power off
First off try unplugging it and leaving it unpluged for 30 minutes. Not just turned off, but unplugged, then plug it back in and see if it works. There are filter capicitors in the low voltage power supply that sometimes have to sit with power removed for 30 minutes before they discharge and allow the power supply to turn on.
Sounds weird but I have seen it fix a dead machine probably 50 times or more. If that doesn't restart then you will have to replace the power supply. If that is the case let me know and I can tell you where to get it from and ho\w to replace it.
Try leaving it unpluged for 30 minutes. not less than 30 minutes.
Oct 16, 2008 | Xerox WorkCentre M20i All-In-One Laser...
GREMLIN POSSESSED!! received fax error causing endless pages of arrows
Switch the machine off. hold the menu button in and switch the machine on while holding down the menu button.
the machine will boot in service mode enter 91 the machine will init., then press 99 the machine wil start-up normally
Apr 14, 2008 | Brother MFC-7820N Laser Printer
Open Questions:
See all HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Questions
HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop Logo
245 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
