Question about HP DeskJet 3550 InkJet Printer
I HAVE PROBLEM IN INSTALLING SOFTWARE
Good Day,
i install the driver software in my windows xp pc , long time detecting the printer can't detect
pls solve the problem
  • kamblev94 Jan 11, 2009
    yes, i also have this problem ?
  • Justin Washburn May 11, 2010
    What kind of cord is it connected to the computer by? Serial, parallel, or usb?
  • 535 Answers
U have chak ur usb cable has been damged or not working take new usb cable & connect it reinstall driver
Posted on Jan 11, 2009
My printer ( canon LBP 2900) cannot connect to windows 7...
Did you load the software for this ? Might need to be re-installed
Jul 12, 2011 | Computers & Internet
HP OfficeJet 6110 All-In-One InkJet Printer Problem installing driver downloaded from HP for Windows XP - when I execute file it takes a very long time to install then stops
In most cases the printer driver software can have errors whilebeing in use or is shut down. So to reset remove your printer from the PC anduninstall the printer software. Now reinstall the printer software and then connectthe Printer to be detected as a new hardware as it will be installed. Now checkthe printer properties to see the ink levels.
Jun 15, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Its says , you may be a victim of software counterfeiting and this copy of windows did not pass genuine windows validatio.. and my dest top turn black.. pls help me to fix it.
Hi
If you install copy of WIndows XP operating system, do not update it or get update it through internet as it will detect that you are using counterfeiting or pirated software. Just reinstall again the operating system and this time do not get update from internet when installing. Ever it pop up to your computer, just ignore it. Otherwise, that will appear.
Good Luck.
Jan 13, 2011 | Microsoft Windows XP Professional for PC
I have problem to install window xp in my laptop, which already have window vista....my notebook donot support to install xp..please tell is there any way to install xp...
What is your problem specifically? Is it that there is no hard disk detected when you try to install windows xp?
Try using third party software to detect the hard disk on your laptop
Try this link. It will basically give you your hard drive driver while installing windows xp. You will also need an external floppy disk drive if you dont have diskette drive in your laptop.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70477
Jan 24, 2010 | Computers & Internet
Is hp pavillion 7840 compatible with windows xp operating system
yes , all operating systems cn be used in any desktop.
Sep 13, 2009 | HP Pavilion 7840 PC Desktop
I need to install/update my Canon Pixma iP1700 driver but everytime I run the supposed correct driver/update it constantly fails. This printer worked perfectly on my old printer with Windows XP but I...
Did you do a upgrade to vista from xp? Or is the computer with vista a different computer? The reason why I ask is if you did an upgrade the old drivers and software for xp may still be in the system. The first thing I would do is go into the device manager and remove the printer and un-install any software for the printer. Re-boot the computer and windows vista should detect the new hardware. I would let vista check online for the driver and install it. If it cant't find one the choose the driver you downloaded online. After that then try installing the printer software. Also make sure that when you go to print something that your printer is set up as the default printer.
Sep 06, 2009 | Office Equipment & Supplies
Brother DCP165c Driver installation Problem
I would boot in safemode (hold down f8 immediately when it starts (when it says Starting Windows xp), then delete all printers (associated with this) in device manager.
remove any printer software as well (add remove programs or start programs (printer program name, remove software IF listed),
also remove the port you are using in device manager be it lpt or usb. if the drivers siuggests installking without it connected do so, otherwise, just restart and it shoudl start installking the hardware amnd software it finds. be sure you have the correct drivers ready as well>
Good Luck
Jul 09, 2009 | Office Equipment & Supplies
HP deskjet F380
If you are running Win XP or Vista, you may wanna try the steps below:
1. Start > Control Panel
2. Printers and Faxes (for Win XP) - Printers (for Vista)
3. Click the "Add a printer" of the upper left hand corner of your screen.
4. Select Local Printer.
5. Connect your printer to the USB port and turn it ON.
6. Try to detect a Plug-n-Play (PnP) printer
7. If the printer is not detected as a PnP printer, run through the unstallation wizard and select the HP F300 series or F380 > Next
8. Run through the wizard until you finish the installation.
The steps above are the steps for installing the printer driver using the generic printer drivers that are already installed in every Windows computer .
If the generic driver will not work, you may download the driver through this link:
http://www.softwaredriverdownload.com/hp_deskjet_f380_printer_driver.html
Hope it helps and have a great day!
Jun 15, 2009 | HP DeskJet F380 All-In-One Printer
Upgrade winXP, now ATI card not recognised and drivers wont insta
hi im josh in cebu phils. friend if it happened when your video card cannot be detected or recognized.try to check if the software updates of xp through the net then after the update try again installing your video card.so as the driver software. good luck hope i helped you
Mar 06, 2009 | ATI RADEON 9200 SE (128 MB) AGP Graphic...
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
HP DeskJet 3550 InkJet Printer Logo
54 people viewed this question
Ben Johnson
