Question about Toshiba Satellite A100-S8111TD Notebook
How to correctly install new screen for a105
I ordered a new screen for my laptop from Toshiba. I previously had laptop hooked up to another monitor. My computer will not display the new screen attached to the laptop. How do I make sure screen attached is in default?
  • Toshiba Master
  • 4,338 Answers
Here is a pictorial on how to replace the screen on an A100:
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 12, 2008
  • 320 Answers
On the keyboard their is usually a button/key that will switch video outputs. Usually it will have a small picture of a screen and may require you to hold down the "FN" key while pressing it.
Another thing to check is that the backlight for the screen is not bad. This is a small bulb that runs along the bottom or top of the screen.
For the most part if the monitor is not plugged in the laptop will auto-detect which display to use.
You may also want to check the bios settings for "Video adapter" settings. This will of course need to be done using the external monitor.
Hope this helps you in some way.
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
When I boot up my Toshiba A105 the monitor goes blank / black screen right after the Toshiba window. What is wrong with my laptop?
There is a video driver error, possibly just a corrupt file. Not easy to repair! You may need to reload your OS.
Try F8 as windows boots and select Safe Mode. If you can get in that way, restore your machine to a previously known good restore point.
Oct 06, 2012 | Toshiba Satellite A105-S4397 Laptop...
Toshiba screen is blank ans light on under F10 key.
Is the screen completely blank, or just dim? If it is dim, then most likely your lcd power inverter is bad, and needs to be replaced, which is the cheapest part to replace. If it is completely blank then you should try to hook up an external monitor to the laptop, and don't get any video, then most likely there is an issue with your motherboard or video card. The external monitor method sometimes needs you to press a combination of the Fn key and another F key in order to switch from your laptop lcd to an external monitor.
Feb 06, 2010 | Toshiba Satellite A105 Notebook
My Toshiba Satellite A105 screen comes on for a little bit, flickers and then shuts off. However I can faintly see the screen, and the laptop works fine when hooked up to the external monitor. Wondering...
If you can still view screen if you view it in an angle or spot a flashlight on screen. Then, definitely it is a problem on backlighting, might be loose connection, inverter giving up or cfl giving up.
Hope this helps
Nov 06, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite P105 S6147 screen won't illuminate when on?
first try the fn+lcd/crt and see if it toggles on.if not then try hooking it to an external monitor. if you get the pic on the external monitor then you have a backlight or inverter problem.
Jul 27, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite Laptop refuses to allow Dual Monitors
I have an A105 set up on dual screens, and it works great. As I recall, you have to do the dual screen setup in the control panel, display, settings.
Mar 17, 2009 | Toshiba Satellite A105-S4074 Notebook
Toshiba satellite a105-s1014
try the computer with an external monitor, if it works correctly then it's the monitor that has broke and you need it replaced.
otherwise, if it does the same things on the external monitor...
I would check in order:
1)RAM memory
if the problem is only after windows boot, try changing the video driver, the problem might be caused by overheating video Chip, but that should freeze the system too...try also to remove the dust from all the heatsinks with canned air...
Jan 18, 2009 | Toshiba Satellite A105 Notebook
Toshiba a105 screen goes blank
Sounds like GPU failure. unfortunately its nigh on impossible to replace without replacing the whole board which can be expensive. I saw a few on ebay for around £120.
Aug 14, 2007 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
