Question about Thermador SMW272 Electric Double Oven
Oven will not heat - Thermador SMW272 Electric Oven
I turned the oven on and it acts like it will preheat. However, it never does warm up at all. The broiler will heat.
How do I find out if it's the bottom element gone bad? I don't have an ohm tester which I noticed someone mentioned on their question.
Appreciate any help.
  • Mary Sutton Dec 14, 2008
    I cannot disconnect the oven from the wall. I really want to have an oven with both broiler and bake elements working.
    Thanks.
  • Mary Sutton Dec 18, 2008
    I don't know how to remove the bottom element? Is there something to unscrew some where?
    thanks!
  • 71 Answers
Since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Posted on Dec 12, 2008
  • 1 more comment
  • flyingtarzan Dec 14, 2008
    can you remove the bottom element? just make sure the power is off.
  • Jasna Gruban
    Jasna Gruban Jan 11, 2013
    replaced heating element heather and now I am stacked, don't know what cloud be the problem.
  • Jasna Gruban
    bake and broil work
Thermador oven runs but no heat
check the relay board for a bad solder connection on the underside below one of the relays. repair or replace as needed.
Sep 28, 2014 | Thermador SMW272 Electric Double Oven
Pre heat works on smw 272 yw but oven or broiler do not heat.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ';';
Sep 22, 2011 | Thermador SMW272 Electric Double Oven
Oven will not heat up broiler works. its a thermador rdss oven
heatman101 ';
Mar 07, 2011 | Thermador SMW272 Electric Double Oven
Oven displays Off with every button you push
touch panel has failed . may need replacement . . this unit may require a update kit .. ( new p c control and panel .. ) very costly. mm
Jul 13, 2010 | Thermador SMW272 Electric Double Oven
Thermador smw272 oven does not heat. the op panel
Likely to be the Hi Limit Switch or the relay/power board.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Thermador C302U Electric Double Oven
Teperature i snot rising above 100, why?
Assuming your Thermador is electric, and it is only warming up a little, this is usually one of three things:
1. Heating element - with oven power disconnected, check that the elements resistance is in spec. Usually around 20 ohms.
2. Thermistor - this senses the temperature of the oven. Again, check the resistance. Depending on your model, it should be around 1050ohms at room temperature.
3. Electronic Control Board. These can be rebuilt quickly and reliably at www.fixyourboard.com. Some are still available to buy online.
Hope that helps
May 21, 2010 | Thermador SMW272 Electric Double Oven
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
Thermador SMW272 Electric Double Oven Logo
847 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
