Question about Olympus FE-170 Digital Camera
Stupid camera i turn the camera on, it works. i can view all the pictures no problems like that but once i hit the picture button to take pictures it doesn't work it makes a funny loading sound and the screen goes black ? so i cant take any pictures? help..?
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
The camera appears to need repair, either in the lens or contol panel... you can try to reset the camera then send to repair
Posted on Dec 16, 2008
Camera won't take pictures LCD also won't work
get out your manual and find out how to do a reset. Then read the manual. if you can't do a reset take it back to the dealer you bought it from.
Jun 16, 2009 | Canon EOS Rebel XSi Digital Camera
When I view my pics on camera, I cannot view back (left)
janet
when you are view your pictures you have taken you are hitting the little movie camera button which is at the top of where you are pressing the arrow back and forth. just hit that button again and the
microphone will go away. I have had this happen to me. the button are small and our fingers are to big. once the microphone goes off you will be able to push the arrows to view your pictures forward
and backwards.
hope i have helped you
connie
Jan 18, 2009 | Samsung S1050 Digital Camera
Camera turns on then immediately shuts off
I have the same problem - 4 fast beeps and it turns off. My guess is that the lubricants are getting old and sticky - I had a Canon SLR that developed the same problem after being in the extreme cold. Here's a couple of things to try:
  • You can still access the picture review features by holding down the review button while you turn it on (note that if you hold down the trash button you'll see the firmware version.)
  • What doesn't work: Resetting the camera from the setting menu; replacing the battery, replacing the SD card, cursing.
  • I've been able to consistently get it to function normally by hitting the camera into the palm of my hand on the left side (with the viewing screen facing you), just after turning on the camera.  If this doesn't work, keep hitting harder until it works.  Once on, the camera works normally.
Aug 16, 2008 | Pentax Optio W10 Digital Camera
Power key doesn´t work
There must be a problem with your batteries. If you have recently charged your batteries and it happens again, you should try a new set of rechargeable batteries.
You can try conserving charging power usage on camera by turning the flash off so that it doesn't precharge for the next shot.
Jun 04, 2008 | Samsung Digimax i6 PMP Digital Camera
Sony cyber shot
you most probably have your camera in slideshow.
if this is the case:
  1. turn the camera on and press the button to view your pictures
  2. press menu and use the left and right arrows/buttons to press 'slide'
  3. hit cancel
hopefully this will work.
good luck with it!!
Dec 07, 2007 | Sony Cybershot S650 Digital Camera
Button don't work
One of the buttons is constant presset in.
Under the button is a metal membrame, sometimes it happens by to mutch force the membrame is defect, it doesn't popup again.
Try to find out witch button doesn feal good anymore, can you work without it ?(for example left macro), open camera and remove membrame.
LKet it repait by fuiji ? a least € 100,-.more than new....
Nov 12, 2007 | Fuji FinePix A310 Digital Camera
Camera seems to ignore all buttons
I have the exact same problem. I purchased a new battery, but still have the same issue. Any ideas?
Sep 20, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Unable to take Pictures
So, you're using Ni-MH batteries already, once you've turned it on and then you have to press on the PLAY button to view pictures, i need you to double check the battery type option of your camera by doing the steps below:
- Press MENU
- Scroll to the right until you are in SETUP 2
- Go down to Battery Type
- Switch it over to Ni-MH (for Rechargeable batteries)
- Select Alkaline (for Non-rechargeable batteries)
- Press MENU/OK for changes to be saved
Turn off camera for a few seconds so settings will be refreshed.
Turn on camera without pressing on the PLAY button to double check if it works.
If it does not work still, try to turn on again camera and immediately press on PLAY button to view pictures. Try to press again on PLAY button so you'll be on the mode to
take a picture.
If it still does not work, can you please try Non-rechargeable batteries (Alkaline) with your camera if it won't work with the Nickel-metal Hydride (Ni-MH) Rechargeable batteries.
Make sure you have set properly the battery type of the camera under SETUP 2 for Alkaline.
take a picture.
If it still won't work, then you have to send the camera for Repair.
Register camera online:
- Go to www.samsungcamerausa.com
- Click on Customer Service
- Register under Option 2 Box
- Fill out the required info
- Read instructions
- If website asked you to upload a receipt, just skip that
step and leave it blank
- Take note of the ASC address and online ticket number
that will be generated at the last step
- Turn-Around-Time will be 7-14 business days
Do the following:
- Include a copy of receipt in the box to avail of the warranty
- If you don't have any receipt, include a copy of credit/debit card statement/cancelled check that was used to purchase the camera
- Exclude all accessories when sending camera for repair
(No batteries, memory card, strap, cables, manual, CD)
- Write the online ticket number on top of the box
- Use another box and sealed it properly to avoid damages during shipment
- Check repair status using Online your zip code and phone number as you proceed on the Repair status of the website
Sep 14, 2007 | Samsung Digimax S630 Digital Camera
Won't turn on in Picture Mode
  • I've been able to consistently get it to function normally by hitting the camera into the palm of my hand on the left side (with the viewing screen facing you), just after turning on the camera.  If this doesn't work, keep hitting harder until it works.  Once on the camera works normally.
Jul 02, 2007 | Pentax Optio W10 Digital Camera
Olympus FE-170 Digital Camera Logo
185 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
