Question about Epson Stylus CX6600 All-In-One InkJet Printer
Not Printing I lost my setup disk, ordered a new one from Epson, reinstalled it and now my printer is not printing anything. I have all new ink cartridges. Epson told me to take it to a service center, but I can't afford this at this time. I have had it less than 2 years. I thought maybe it was imcompatible with my new tower. But, I took it to a friends and set it up on their computer and it didn't work either.
  • Epson Master
  • 705 Answers
You may have a split tube on the pump cap or it could be that with standing for a while the ink in the pipes to the waste pad has gone hard. Get in touch with the people at http://www.TheServiceManualShop.com and ask them for the information on the Loss Of Ink Rescue Kit. This should help you get it going again.
Posted on Apr 12, 2007
SOURCE:
Epson printer is not printing correctly
Reinstall driver first if problem is still then change data cable to solve the problem
Sep 28, 2014 | Epson P50 Inkjet Printer
Epson stylus cx4300 series is not printing because there's no black ink but colored ink cartridge are almost full.
Hi guys i need help
i have problem printing to the epson cx4300,it s not printing black,i have change the ink tested it,made sho that the ink is not dry,reconfigured my computer but still,uninstall drivers reinstall on the computer.it jus not printing,what is the problem.
please help
Dec 05, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx8400 printer "setup" bbutton not responding
lost disc and want to download my epson to this computer
Jan 04, 2010 | Epson CX8400 All-In-One InkJet Printer
I put new ink cartridge and is not printing
clean cartridge if you are not active print docoments then change printer head
Oct 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Its not printing anything, I've had it for a couple years now, I just changed the ink after this happened, thinking it was out or gone bad... I've checked the new ink, making sure no plastic was in the...
Problem with printer main board. Usually, it's caused by short circuit at head. If you have experience in electrical circuit and soldering, check mounted fuse at main board. Check for f1 and f2 fuse. If the fuse is off, replace it. But you must check the head first. Find the reference in aicaxz solution for this condition. There are same condition as your printer, that resolved with this technique. But, if you don't have experience better take to epson service center.
Head cleaning is mechanical process, printing is electrical process.
Oct 20, 2009 | Epson Stylus Photo R300 InkJet Printer
Printer wont work just feeds paper straight through
First try reinstalling driver software on your computer.
Either use printer CD or download from website:
Epson Driver Download
Epson America, Inc. - Support
If problem persists after downloading software, then that means that ink had clogged the printheads after drying up on old installed cartridges.
In that case either order a new printhead from Epson, or replace the printer.
Feb 03, 2009 | Epson Stylus C46 InkJet Printer
R220 epson printer not printing
ensure u r using original ink cartiges try head cleaning process replace all the ink cartriges
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
My r220 epson will not prit anything
The ink indicator permanently on indicates an ink cartridge problem, (not that the protection counter needs resetting). The status monitor picture of the ink cartridges should show which cartridge is at fault, it will have a red X on it. The cartridge is empty, faulty, or in the wrong position. Alternatively, you may have an internal fault e.g. with the system board. But change the indicated faulty cartridge first.
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Black and yellow ink not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 18, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
