Question about Canon PC-940 Black and White Copier
Canon 745 I have a canon 745 copier. When I turn the unit on it fires up like normal. When I press copy the unit starts, I hear the paper being feed and then the unit shuts off. I error code comes up E0. I called a teck near my home he took the unit said the heating element was bad. Two weeks later he came back said he could not get part. Found out he was not a canon service man. What could be my problem and what can I check or do. Thanks john Jmuel5@excite.com
  • Anonymous Dec 14, 2008
    Sorry but the code does come up as E0 I did find out the the fuser unit had a bad conection thanks for the help any.
    John
  • 76 Answers
Hello sir
machine error code zero is the first digit when its blinking,there is another # to show? must be 2 digit,but base on your explanation you must change the exposure lamp or scanning lamp
Posted on Dec 12, 2008
CANON IR3750 PRINTER AND COPIER
Seemms like you have contamination somewhere, open the unit and clean any blobs of ink then follow the on screen instruction to fold a piece of paper and feed through the unit from the rear feed, this will remove any internal contamination you may need to do this several times untill the paper comes out clean
Kevin
Dec 06, 2013 | Canon imageRUNNER iR C2880 Color Copier
I have a Canon PC 980 B&W copier. When I try to print, the "P" (no paper) light comes on, even thoug the paper tray is full.n
YOur problem is likely worn feed rubber. It is an old machine. Has it ever been serviced?
Did this happen after a paper jam?
Try this: UNPLUG the copier Take out the paper tray. Prepare a dry cloth that is dampened with WD 40. Open the door on the right side of the coper. You should see 1 large, gray or black rubber roller. Gently wipe the roller with the WD 40 cloth, slowly turning the roller. It only turns 1 way, towards the exit direction of the paper from the copier.
Let the WD 40 soak in, about 10 minutes. Put the paper tray back in, plug the copier back in and try to make a copy. If it makes a copy, the feed roller needs replaced, If it doesn't make a copy, check the top sheet of paper in the tray. If you see skid marks, you definitely need a feed roller. No, they are not easy to change.
As long as the roller feeds, go for it. When it starts slipping then you'll have to do something about that feed roller.
Jan 24, 2011 | Canon PC-980 Color Copier
When I try to make a copy the error code P flashes and paper in unit jams but I can still make copies thru bypass
P error normally indicates that you need to add paper. If there is paper in the cassette and the paper is raising up to the roller then the paper feed rollers are most likely dirty. You can clean the rollers with a cloth and some rubbing alchol. Also make sure you dont have a small peice of paper or something in the paper path causing the paper not to feed. Also listen when you press the prnt/start button and see if you can hear the paper feed clutch turning on then the paper feed rollers turning.
Jan 16, 2011 | Office Equipment & Supplies
Canon pc710 copier paper feed, no longer grabs the paper for copying.
change or clean the feed pickup roller in the tray unit. To clean it take some alcohol and a cotton rag and clean the rubber roller
Mar 28, 2010 | Canon PC170 Copier
Canon PC-745 stopped working.. paper jam light
Sooner whole in трее there is what that subject , can broken part or scrap of the paper. Open and see attentively, in that place, where paper sticks. I for its work so much took out stranger a subject(
Sep 05, 2009 | Canon Office Equipment & Supplies
Lines repeating on copied paper from Canon PC 745 copier.
You probably have a piece of paper wrapped on your pressure cleaning roller inside the fuser. The patterm on the paper is the same and the spacing is equal and it is in the direction or feed.
Apr 11, 2009 | Office Equipment & Supplies
Canon PC 745 error ''8'' plus zigzag. What does it mean?
try to see if there is any paper in the way out of maxine (fixing unit ) or on the right side of the machine you have paper jam thats the signal zigzag
Dec 27, 2008 | Office Equipment & Supplies
Canon PC-940 Black and White Copier Logo
186 people viewed this question
old marine
old marine
