Question about Kenmore 23822 Top Load Washer
Washer washes but will not spin out the water
I have a Kenmore 70 Series washer. It washes and when that ends the machine stops. If I move it to the rise cycle it will start agitating again and then it stops again
  • 71 Answers
The problem is most likely the lid switch
Posted on Dec 12, 2008
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Water won't drain
This is usually caused by the lid safety switch. When the switch malfunctions, The washer believes the lid is open and the washer will not spin or empty. The switch is intended to prevent injury during the spin cycle. The timer could be bad but it is usually the switch..
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Kenmore Series 70 Washing Machine - won't drain water
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Feb 15, 2008 | Washing Machines
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 23822 Top Load Washer Logo
130 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
