Question about Frigidaire GLTF2940ES Front Load Washer
The washer make a humimng noise and don't complete the draining stage. I remove all clothes from of it, and still have some water
  • 750 Answers
Heool Welcome to Fix ya,
Is your drain pipe at the same level as the top of the machine?
You may have any of these two common problems!
Defective Water Pump
If the motor is running and water is not pumping it could be a defective water pump. Ensure the tub to pump water hose is clear. If so, replace the pump.
Defective Motor
If the motor is not running, the pump will not work. Most washing machine use a reversible motor and it is possible for the machine to agitate and not spin or drain.
They need to be diagnosed to know which to replace. You will need a capable hands on tech there to do this!
Please remember to leave a rating before you sign off!
Posted on Dec 12, 2008
Whirlpool Cabrio Washer does not spin the water completly out of the clothes
probably not getting into high speed spin mode
they spin slow in the initial stages to allow the clothes to become evenly distributed then after the water is removed they pick up speed
It is possible a problem in the program board not advancing to high speed
Call in a technician for a proper diagnosis and a quote
Jul 07, 2016 | Whirlpool Washing Machines
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Asko WCAM1812 makes noise when draining
I recently had this same problem. There is a spinning wheel inside the pump that has likely detached from the motor. Upon removing the back of the unit, you will see a water pump on the bottom left of the unit. There are three screws attaching the pump to the rest of the assembly, remove the screws and detach the motor, out should pop out a red spinning wheel. I Gorilla glued mine back on, and it sounds better than before the grinding noise.
Feb 13, 2013 | Asko WCAM1812 Front Load Washer / Dryer
Maytag bravos washer will not complete cycles
Remove clothes from drum. Siphon out (or wet vac out) visible water in the drum. Blow into drain hose. This back flushes the system. After hearing gurgling and seeing bubbles come up thru the drum, you know its a fairly clear line. Now take your wet vac and siphon out remaining water by connecting it to the drain line using duct tape. The lights will correct themselves and your washer will now work normally. At least this is how I fixed mine without disconnecting anything or making a big mess. Good luck.
Apr 17, 2012 | Maytag Bravos MTW6600T Top Load Washer
Water not completely draing out of clothes after wash is completed.
That can only be one thing: String or coin in the electric pump.
It can be easily removed and taken apart.
Once yall get the front off the pump is at the bottom right. A couple of 3/8th screws hold it to the floor. The drain hose and tub hose gets removed. Take the power leads off and remove it from the machine. Water will go everywhere so don't let none get on the washer motor.
Service manual and more HERE
Aug 22, 2011 | GE WBSR3140DW Top Load Washer
The washer will not drain & spin out completely. It makes a rattling noise which is not usual.
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fisher Paykel will not drain
I had the same problem. After cut the power off for at least 60 seconds and then back on, as the manual suggests, the problem remained. Therefore I started putting the clothes out and bailing the water out. Once the water was down about half way the pump started working. I suspect the sensor was "stuck". I cycled the washer without clothes and it worked fine. Still working after several loads of laundry. The water level sensor will probably need replacing sometime soon.
Dec 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer making noise in spin cycle
Is this unit new? I had a frigidaire that would really get to going on the spin cycle. Got the clothes really dry and sounded like a jet engine if no clothes were in it. Is it a whisling sound or screeching sound...The sound could be coming from the water pump. It may have something in it that is dragging. Some you can take the bottom off of and clean them out..
Feb 10, 2008 | Washing Machines
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
SPin CYcle Noise
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump. Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then try to remove the clothing through the port.
Apr 16, 2007 | Kenmore 42722 Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
55 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
