Nu cdrw/dvd dbw-521 draw opens and closes repeatedly
The draw of my cdrw/dvd keeps opening and closing. I use the close button when I operate the device but it seems not to want to synchronize the drawer with reading the cd/dvd
  • paperlessads Dec 14, 2008
    No I don't have a virus. Is seems more like a mechanical fault because if I hold the tray momentarily whilst it is trying to close sometimes it will line up and behave for a while.
  • eliasm1960 Dec 23, 2008
    I have the same problem. Also noticed a yellow ! on device manager
Hello!
This sounds mostly like you got a Virus in your system, please make sure you got a good one like or Antispyware....
If you are familiar with windows services and startup Items you can find the one that is infected.
Let me know...
Posted on Dec 14, 2008
  • alfredo103 Dec 15, 2008
    IF that is the case then the only reason could be that the EJECT button is having a malfunction, then it should be corrected cleaning the part with a good Di-Electric Spray that can wipe out the grease from the area, else try replacing the Drive, (there are many cheap ones) if you still experience this problem after replacing the drive then YOU HAVE a VIRUS FOR SURE
    Regards!
How to remove dvd drive
When does it open on its own?Sometimes it is easy to be press the open button as you close it which of course opens it straight away.It can also fail to lock closed if not opened further than its initial amount that it does open.To close it after it opens you need to draw it back to rearm the mechanism.
Sep 01, 2014 | Toshiba Tecra Computers & Internet
Sun Roof mis operation
Try when closing, hold button for 5 seconds when already closed and attempt to open. If it opens all of the way. Keep button depressed and hold button when it gets all of the way open,hol for 5 additional second and repeat this open and closed. This will tell the body sunroof ecu Walt the travel limits are
Apr 06, 2014 | 2003 Toyota Celica
Does not read or write cds
Hello, Robert.
If no CDs work with your drive, try cleaning with a CD/DVD disk head cleaner.
If still a problem, the drive would need to be replaced.
Hope this helps.
Sep 09, 2010 | NuTech Nu Tech DBW-521 CD-RW+DVD Combo...
Dvd slider door won't close.
Hi, is it fully open, or just partially open?
Is it nearly shut but just jammed? If so have you tried inserting a flat peice of plastic and pulling the draw open. You could do this with no power to the dvd player, It might be that you haven't inserted the disc properly and it is wedged in.
Try all this and see how you get on.
Regards - Anthony
Feb 14, 2010 | Memorex Televison & Video
The dvd draw for our LG cinema system keeps opening
Your open button is hunk to the inside or the spring wont hold the button out.
Dec 12, 2009 | Audio Players & Recorders
DVD Drive door will not always open. No obstructions. DVD Drive light flashes, but door will not open. Is ther some software conflict?
The door drive motor may be frozen.
  1. Shut down the computer and unplug it.
  2. Open the computer casing to access the DVD drive from inside.
  3. Disconnect the cable on the DVD drive leaving only the power supply connected to it.
  4. Turn on the computer.
  5. Push the OPEN/CLOSE button on the DVD drive. If it does not open, the drive is broken or the door drive motor is defective. If it opens, push the button repeatedly to open and close the door repeatedly to release any frozen part.
  6. If the door does not stuck anymore, shut down the computer.
  7. Reconnect the cable and turn on the computer.
Oct 30, 2009 | Sony Computers & Internet
I have connected my dvd player to my tv and although I can see the picture there is no sound
You have a three port yellow-red-white port. Plug the port's yellow end to the yellow plug point of your TV & DVD player both and this way red to red and white to white. I think it fix your problem.
May 16, 2009 | NuTech Nu Tech DBW-521 CD-RW+DVD Combo...
Unit only displays "hello"
This is a faulty condition caused by lack of error control in the firmware. Try this:
Unplug machine from wall for 5 min. Hold "open/close" button in and then plug machine into mains whilst continuing to hold the open/close button. Keep holding open/close button for about a minute, as these machines are notoriouly slow to "boot". It that doesn't work, repeat the procedure, but hold down the power button instead of the open/close button in an attempt to reset the memory settings of the unit. Good luck.
Feb 08, 2009 | RCA DRC8320 DVD Recorder/VCR
Door on DVD player
The drawer seems to hang up when it sits closed for a while. I found that using a very thin but rigid metal item such as a nail file under the leading edge, allows it to open with the first press of the  open/close button. I load the DVD, press the open/close button and it closes and stays shut.  After I submitted my problem, it occured to me that the reason for the door to continue to open and  close, was the repeated pressing of the button. The door was merely responding to each time it was "called."
Jan 15, 2009 | Sanyo DVW-6000 DVD Player/VCR
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Computers & Internet Logo
242 people viewed this question
David Payne
David Payne
