Question about Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
Not reading DVD
I have a compaq presario 2500 series with a sony CRX830E combo drive. Since recently my CDROM drive is not able to read "only DVDs'. Other CDs are working fine. Also i'm having a problem with burning CDs as the software (nero, roxio) freezes in between and the drive locks up. Kindly suggest what to do.
  • Ryden Jan 30, 2008
    My Dell Latitude D600 just developed the same problem, I installed VS Express 2008 (from DVD!) and the MS XP patches for the last week and it will only read CDs now
  • js2000tomcat Oct 26, 2008
    my sony CD-RW CRX 803E doesn't wan't to read any cd/dvd discs
    President:
  • 2,961 Answers
It's common problem with combo drives in notebooks, they don't seem to last long. Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If the problem persists the laser is faulty in the drive and the drive will need to be replaced.
Posted on Mar 23, 2007
My crx830E CD-RW/DVD-ROM does not read nor open DVDs & CDs. Please give me advice for the solutions? to repair !!
Posted on Nov 30, 2008
What type of disc does a sony crx830e support
This is a combo drive
It will support
1. CD reading & burning (Blank CDR and CDRW)
2. DVD reading only.
We cannot use a combo drive to burn DVD.
Jan 02, 2011 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
My Sony CRX830E combo drive will not read any of the DVDs I have tried to play in it. The message it gives is that a compatible decoder is not installed. Is this a software issue, or do I have to buy a...
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no _ for your specific area
Jan 02, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Can't read all kind of dvd..
hi,, there are different kinds of DVDs ,, some are DVD+R , DVD-R ,,and dual layered dvds so.. please check the details for support of dvd , cd drive...
Sep 27, 2009 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
My dvd rom wont play dvd only cd's
DVD/CD players use two different lasers. One to read DVD and one to read CD. Sounds like your DVD laser burned out. Lasers last about as long as light bulbs do.
Jan 17, 2009 | HP Compaq Presario V2000 Notebook
Hi my dvd rom wont play dvd's only cd's by the way my dvd rom is sony cd-rw crx830e on my compaq v2000...what shall i do???plz help me..tnx
Try installing a DVD rom. The sony unit installed in your laptop is a cd rom/burner. Cd roms will not play DVDs.
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
My presario R3000's combo drive no longer wants to burn dvds
Try a different Brand Of DVD Maxell Typically Work Universally With Failing Drives or older Drives or touchy drives...
Nov 17, 2008 | Compaq Presario R3000 Notebook
Sony CRX830E CD-RW/DVD-ROM (Combo) Burner Logo
684 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
