Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic TH-50PX60U no buttons working
Remote control stopped working (except power) and front panel buttons (except power). Ordered firmware update from Panasonic to fix the problem and TV won't respond when SD card is inserted. Unplugged TV to reset and still no luck.
Any suggestions would be appreciated.
  • 1 more comment
  • Anonymous Dec 29, 2008
    the tv shuts off and I cannot restart it now
  • ursmacker54 Jan 25, 2009
    My remote control doensn't work except the power button and none of the buttons on the tv will work except the power.
  • Kaashif Feb 03, 2009
    while watching it, the tv just shunt off. no help with front botton. I unplugged it, but still nothing...
The software in the cpu of this set is damaged you must reload it to fix the problem..
Posted on Dec 18, 2008
  • josephbart
    josephbart Nov 30, 2012
    Very helpful. Disconnected power cord from outlet, then reconnected. This reset my system. What a relief!!
Panasonic TH-50PX60U powers on but no picture
Check the led circuit if you have sound. Inverter circuit or led themself. Good luck.
Serge.
Feb 24, 2016 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Where is the power button on Panasonic 50" plasma
The "power button", which may be identified merely with a symbol usually is located at the top of the universal remote although some place the power button near the bottom.
Jan 05, 2014 | Panasonic TH-50PX60U 50 in. Plasma HDTV
When the Panasonic TH-50PX60U is turned on, the button beside the power switch flashes 10 times, stops and repeats the flashing. The tv will not actually turn on.
10 times red light blinking shows problem with PA board and/or H board, both boards are available in shopjimmy.com for $35 and $45
Replace required board to solve this issue.
Hope this info will help you.
Thanks.
Jan 21, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Volume control does not work using the TV's remote, the cable remote or the actual volume control button on the front of the set - the volume that comes out of the TV's speakers is constant - about 33% of...
SO YOU JUST GOT A NEW TV ...BUT...THE VOLUME CONTROL IS NOT WORKING FROM YOUR CABLE BOX.
EASY! BRING UP THE IMAGE OF YOUR REMOTE FOR
YOUR CABLE (MORE THAN LIKELY, IT'S A UNIVERSAL).
CLICK ON THE REMOTE FOR INSTRUCTIONS FOR VOLUME LOCK.
IF IT'S A UNIVERSAL REMOTE, CLICK SETUP (TWO BLINKING LIGHTS) TYPE 993, AND HIT CABLE BUTTON.
VOILA! YOU CAN NOW CONTROL VOLUME FROM YOUR CABLE REMOTE!
Jul 03, 2010 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic Viera TH-50PX60U Plasma is stuck on one channel. Only the power function works on the remote and only the On/Off function works on the TV. Any ideas??
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace. For further questions, please add your comment.
May 20, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Won't respond to volume or channel changes red light blinks 20x's when turned off.
It's definitely a firmware problem. I called Panasonic and they were very polite about the entire situation and sent me a SD card with the firmware update. If you don't have time and you're tired of listening to tv at the same volume there is a way to do a hard reset.
I figured that unplugging the unit would do this, but there is one other step that you have to do to ensure that this works.
Generally the power button on the tv is always in the "on" position, this is what allows the remote to work. In order to do a hard reset the on/off button must be in the off position. Make sure that is off, then unplug the unit, let it sit there for a minute or two and plug it back in. If the tv comes back on as soon as you plug it back into the wall/powerstrip then the button was not in the off position.
This isn't the best fix, you'll still need to get the firmware update but it will at least give you the ability to use your tv normally....well until it decides to randomly lock up on you again and you have to do this all over.
May 11, 2008 | Panasonic TH-42PX60U Television
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
669 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
