Question about Kenmore 47783 Electric Single Oven
Touch pad will not allow me turn oven off
Is my control panel bad
  • 979 Answers
It sounds like that is what it is. Purchase it yourself from a local appliance parts place, not a dealer. It will cost you much more. To install it is easy. Just replace wire for wire.
Posted on Jan 29, 2009
CAN NOT CONTROL BOTTOM OVEN
I assume yiu had the electronic oven control repaired. Sometimes the touch pad also goes bad. I have had to replace them at the same time. If the oven indicator lights showing the oven being on shows up on the display it could be that the thermal fuse behind the oven has gone out. this in in the common line and will shut down both ovens at the same time but you will get the control panel to respond to the touch pad.
Nov 23, 2013 | Whirlpool RBD305PDS Electric Double Oven
I have a code on the panel of my upper oven. The code is "FO". I cannot get the oven to respond to any of the touch commands on the panel.
Touch the CLEAR/OFF pad. Allow the oven to cool for one hour. Put the oven back into operation.
Disconnect all power to the oven for at least 30 seconds and then reconnect power.
If problem continues you may have a shorted key panel switch and may need to replace the Control board
Feb 09, 2011 | GE JRP28 Electric Double Oven
The oven is GE JKP15,about 10 years old. Error: F7 - Keeps beeping. Turned on brakers, but it starts beeping again when the braker is turned on.
this code means either a stuck control pad or a faulty control board/display board... one thing to try is turn power off again at breaker and run your hand over all the keys on the control panel firmly pressing each key sometimes you can luck out and free it up if that is the problem and reset power if it starts again you will have to gain access behind the control panel and unplug the ribbon cable to control panel.... if it stops after you unplug ribbon cable most likely it is a bad touch pad assembly if it continues you most likely have a stuck relay on the control board and will need to replace that... i have see the fault require both the touch pad and control board ,but hopefully this will help you ..i assure you it is one of the 2 problems ... g.e servicer for 18 years now and a common problem most of the time happens after a long cooking period or a self clean was preformed recently...
GOOD LUCK
Feb 07, 2011 | Ovens
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
May 27, 2010 | GE Profile JTP56 Electric Double Oven
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
FO error message. Oven light stuck on. No buttons work.
The F0 is a Function Key Stuck error - Replace touch pad or touch pad and control board if it is one assembly. Refer to F1 Test for more information.
How To Perform A F1 Touch Pad / ERC Test
This test is easy to perform and will help you determine whether the Electronic Range Control (ERC, control board) or touch pad is defective when the F1 code is displayed.
Note: With some models, the ERC and the touch pad are one single unit and therefore this test is not necessary. The entire assembly must be replaced.
Warning: If you have any doubts in your ability or safety of the repair, please contact a qualified appliance repair technician.
1. Disconnect the power to the range by either unplugging the power cord, or turning the power off at the circuit breaker. Always make sure the power as been disconnected properly before beginning this test.
2. Access the control panel.
3. Disconnect the touch pad ribbon from the ERC.
4. Reassemble the control panel. Make sure to check for any additional defects such as frayed or lose wires that could be causing the problem.
5. Turn the power back on.
6. Wait up to an hour for the F1 code to reappear. This could be accompanied by an alert such as a beeping sound.
7. If the F1 code reappears, replace the ERC. If it does not, replace the touch pad.
Nov 06, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Error message on Kenmore oven
F-1 is not good. It basically means the EOC (electronic oven control is bad). There is a little test here for a little info:
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 | Ovens
Kenmore 47783 Electric Single Oven Logo
105 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
