Question about JVC Everio GZ-MG155 Camcorder
Camera temperature is too low
When I switched it on , It says " Camera temperature is too low. Keep the camera power on. "
  • Anonymous Dec 23, 2008
    camera temperature is too low
  • Anonymous Dec 26, 2008
    I have the ame problem. Left power on as recommended by the error window which appears on LCD, but still doesn't work. I didn't see how
    to remedy this in the manual either.
  • 259 Answers
SOURCE: CAMERA TEMPRATURE IS TO LOW PLS KEEP CAMERA ON
you must be trying to operate the camera in a cold area when the cold gets to the camera it forms moisture leave it turned on until it warms up hope this helps regards Jim
Posted on Apr 24, 2009
Muzuakshi No
  • 14 Answers
SOURCE: I have a JVC HDD Camcorder GZ-MG135AA.
The best solution is to send the product back to the manufacturer for repair or replacement. If you have a receipt for the product and its within the warranty period (1 year) they will do this free of charge. I can help you with the process.
Muzu
Posted on Nov 12, 2009
  • 5 Answers
SOURCE: JVC Everio GZ-360BU Camera Temperature is Too Low - Keep Power On??
I'm an English guy with the same problem... What you do is keep the power on for a long time, or you charge it up with the charger. Trust me. However, it is very rare for this to occur. There should be a message saying: "Temperature is too low, keep power on." There should be another message reading: "Turn off power and turn on again to check if camera is fully-functional. Thanks for giving me something to do while X-Plane downloads on my Mac OS X.
Posted on Nov 15, 2009
Davidivory1
  • 338 Answers
SOURCE: camera temp is too low keep camera power on pls.
Stop making your movies in the freezer my friend, try going in doors, Hard Drive cameras are only good for proper temp filming, that is why most proper cameramen still stick to 8mm tapes.
Posted on May 27, 2010
  • 8 Answers
SOURCE: My camcoder (jvc gz-mg575ag) camera temperatur is
its probibly early signs of condensation or a little damp air with faults of this nature same as lense cap fault and or condensation fault leave camera plugged in and switched on for a week . when camera has been on for a while dont put it straight into a bag or case leave it a room temp for a couple of hours after use before putting it away .
Posted on Jan 25, 2011
After one or two uses a AA battery no longer powers the camera
Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Jan 03, 2015 | Kodak EasyShare C875 Digital Camera
I just bought a Polaroid 300 and the low battery lights keep blinking, I've put 3 sets of new batteries in it and the lights still blink. Anything else I can do?
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
May 12, 2014 | Cameras
It likes to kill batteries, even new ones.
Unfortunately there is no real solution to this problem other than keeping extra batteries to switch out for the dead ones if you are shooting for a while. Here is what your camera's manual has to say about short battery life:
The battery run time is brief. You are using the camera in a cold environment. Battery performance deteriorates in low temperatures. Keep the camera warm by putting it inside your coat or clothing. - The remaining battery power is not indicated correctly. When battery consumption fluctuates considerably, the camera may turn off without displaying the battery
Sep 01, 2011 | Olympus Camedia C-770 Digital Camera
The camera (option m*5 pentax) got wet (on Songkran in Thailand). Now it works again except that it seems not to be able to load the battery. If I connect the battery charger while the camea is 'off'', the...
Normally when camera gets wet, first remove battery, use dry facial quality tissue to wipe water, keep camera in a/c so that whatsoever moisture inside camera evaporates due to low humidity in AC room for 24 hours . Take hair drier set in low heat mode holding minimum 6 inches away from camera blow warm air in battery compartment, mirror compartment, memory card slot for 2minutes each. Wait for cooling down to room temperature. Put battery switch on. It should work. Wet camera if you switching on main board get short due to flash voltage in side camera.
Sep 25, 2017 | Pentax Optio M85 Digital Camera
Will not stay on.. turns on and then beeps once and turns off.. the battery is fully charged
Welcome to FixYa.
There are three reasons why your camera power ceases while in use.
* The Battery is exhausted
- insert a charged battery or recharged the battery
* The camera is turned off automatically
- turn on the camera power again
* Operation has ceased in a low temperature outside of the camera usage temperature range
- make sure the camera and battery warm by placing them in your pocket, etc. and then immediately before shooting,place the battery in the camera and then shoot.
In your case, posible will be the 3rd reason. If you still having the same issue after doing the troubleshooting. I also suggest to removed and re-insert the battery and try to switch it on again.
If this option wont work, you have to contact your service center.
I will be more happy to know if my solution will help you or not on your issues on your camera.
Feel free to reply on this for any question or comments.
Thank you for using FixYa.
Apr 05, 2011 | Samsung TL 105 Digital Camera
My camcoder (jvc gz-mg575ag) camera temperatur is to low keep camera power on plase wait! Now what I do?
Jan 21, 2011 | JVC Video Cameras
My camera is saying, "Camera
first put it on the charger for a couple of hours(while its powered off) then see what happens when you turn it on
Oct 28, 2010 | Cameras
Oct 31, 2008 | JVC Everio GZ-MG30 Camcorder
Camera Temperature
mine is an everio gz-mg37u and i get that same bulls*** on the screen at every power up. First I tried waiting a while then switching all the switches between camera and video mode, record and watch mode, etc. and one time it worked and the message went away. Haven't been able to do that since.
Now what I do is turn it on, wrap it in a blanket, leave it about 10 minutes, then turn the power off and on again. Works fine for me, and if I turn it off and then turn it back on within a few minutes before it cools down, it works fine. There has to be a messed up sensor in this thing that I can desolder somewhere......
Jun 13, 2008 | JVC Everio GZ-MG130 Camcorder
Getting great pictures
Here are some tips for taking great pictures with your PDC 700 camera: * Keep the sun behind you or at your side. Avoid having the sun directly overhead. * Use the Flash On setting if there is a light behind your subject. * In low light conditions, use a tripod to avoid camera movement during exposure. * When possible, take pictures when the temperature is between 13C (55F) and 35C (95F). Temperatures outside this range can affect battery performance. * Keep the subject within the flash range of 18 in. to 10 ft. (0.45m to 3m.) * Avoid shooting toward reflective objects, which can result in "hot spots" in your pictures. If you cannot avoid shooting toward reflective objects, use the Flash On setting . * Periodically clean the lens, the LED area on the front of the camera, and the LCD display on the back of the camera. Use a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
JVC Everio GZ-MG155 Camcorder Logo
43 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
