Question about Frigidaire ATF6000ES Front Load Washer
Error Code E20
This is the third time in 2 weeks that I've gotten error code E20 or E21 and the first two times, my husband took the washer apart and found a sock in the pump. This has probably happened a total of 5 times in the two years I've had the washer, but now it's just getting annoying. Is there a reason it's happening more often???
  • weekendwrenc Dec 16, 2008
    error 20 - How do I get to the water pump and filter, ihave the back off can reach the pump, but whaere is the filter and how do i clean it? thank you
    President:
  • 373 Answers
E20 is a draining issue.check your filter is clean.if this is ok suspect a bloackage in the waste hose or faulty or jammed drain pump impellor
Posted on Dec 12, 2008
My washing machine has a code e21 what do that mean
Please read description carefully about error code
Logik Washing Machine Error 21: "E21"
Error Code Definition: Washer has not drained in allotted / time washer not draining.
How To Clear Error Code:
-Check that filter is not blocked or kinked
-Check drain hose is clear of any blockage or kinked
-Check wires to drain pump
-Check drain pump is not faulty
-Check level sensor and switch
-Check wires to level sensor
here is link for more about your all error code which will may helpful in future, LOGIK Washing Machine Error Codes How To Clear
here is video which helpful regarding solve and understanding error.
Mar 16, 2017 | Washing Machines
It pauses with error code E20 and doesn't seem to drain or spin, could it be the filter is cloged?
The E20 error code is a class code that indicates a drain problem in the washer. This is consistent with the drain and spin problem that you are observing. To determine the exact error code, follow these steps:
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the START and PAUSE/CANCEL buttons simultaneously
The exact error code (E21, E23 or E24) will be displayed.
If E23 or E24 are displayed, you will normally need to replace the control board due to a failed drain pump relay.
If the E21 code is displayed, I recommend that you follow these troubleshooting tips:
Check the washer drain to see if it is clogged.
Check the washer drain hose for a clog or restriction.
Make sure that the washer drain system complies with the installation instructions for the washer.
Try to gravity drain the washer by placing the drain hose in a bucket on the floor. If the washer will gravity drain, you may be able to
unplug the washer
and remove the bottom front service panel using the procedure in the image below. Arrange towels to catch residual water that may be in the washer and check the pump filter and drain trap for a clog or debris. If you find no clog or debris, then you may need to replace the drain pump. NOTE: You should not attempt this procedure unless you are completely confident in your technical ability to safely access and check the pump. Do not disassemble the drain pump hose if the washer is full of water.
May 15, 2015 | Washing Machines
My maschin stops in the midel of a program and E20 comes on the screen. What is wrong?
Sandra: According to ShopYourWay.com: "The E20 error code is a class code that indicates a drain problem in the washer. This is consistent with the drain and spin problem that you are observing. To determine the exact error code, follow these steps:
Wait 5 seconds
unplug the washer
and remove the bottom front service panel using the procedure in the image below. Arrange towels to catch residual water that may be in the washer and check the pump filter and drain trap for a clog or debris. If you find no clog or debris, then you may need to replace the drain pump. NOTE: You should not attempt this procedure unless you are completely confident in your technical ability to safely access and check the pump. Do not disassemble the drain pump hose if the washer is full of water. " There is also a video that may help you, Sandra: https://www.youtube.com/watch?v=s0Wrc2LiCK8
May 10, 2015 | Washing Machines
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
Spin cycle goes very slow or doesn't work.
Hello, After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Thanks
May 19, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
F 02 Error code, took apart and found 2 small
WHAT DID YOU TAKE APART AND FIND THE NAILS? WAS IT THE PUMP? SOME MORE NAILS MIGHT HAVE GOTTEN BACK IN THE PUMP OR THE PUMP IS DAMAGED.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wont spin
check drain pump for obstruction, (access from rear panel) pull hose boot from tub and ck basket in hose. read tech sheet for code definition while your there. have plenty of towels and wet vac ready
Mar 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code E21
E21 Water not pumping out fast enough. .
Check for Restriction in drain pump or hose...
No restriction. Go to step (2).
2. Start the washer and check for 120 VAC at the
drain pump. if no voltage Replace the control board.
120 VAC. Remove the pump and check for
blockage. If blocked, remove the restriction,
if not, replace the pump.
Aug 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
482 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
