Question about Frigidaire Affinity ATF7000E Front Load Washer
My washing machine will not spin, it will wash and then make a buzzing sound during the spin cycle
    President:
  • 373 Answers
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Posted on Dec 12, 2008
the dr
  • 447 Answers
SOURCE: Kenmore Washing machine spins slow
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Posted on Jan 15, 2008
SOURCE: Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Posted on Feb 17, 2008
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
  • 1073 Answers
SOURCE: Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Posted on Apr 21, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Washing machine will not agitate or spin
If you can hear a buzzing sound during the spin cycle and yet the agitator is not spinning, then there is a problem on the motor itself. maybe you should change the motor or its windings.
Jan 03, 2010 | Hotpoint Washing Machines
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Water not pumping out and spin cycle not working.
it sounds like you have something obstructing the pump. does the machine eventually empty? or does it remain with water in it. you need to remove the hose that leads from the tub to the pump and clear any debris. if you continue to run with debris in the pump you could burn out the pump motor
Jul 02, 2007 | Kenmore 44072 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
264 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
