Question about ASUS A7N8X-E Deluxe Motherboard
Hi i'm A ojt technician of computer and I encomtered the problem of computer the problem is system halted... what is the possible deffect of that problem. . .
    Scholar:
  • 56 Answers
It cannot find COMMAND.COM
Explanation: When you boot up DOS, you are placed at what is commonly called the "C: prompt", where you can type commands or run programs. The part of DOS that reads what you type and executes commands is called the command interpreter, which is stored in the file "COMMAND.COM". This interpreter is loaded when you start the system or when you start an MS-DOS session under Windows 95, and is also reloaded in some cases when you finish running a program. In this case, the system was unable to find COMMAND.COM and therefore halted the system.
try this
  • Make sure that COMMAND.COM is in the C:\ root directory, or if it somewhere else, that there is a line in AUTOEXEC.BAT that reads "COMSPEC=X:\PATH" where "X:\PATH" is wherever COMMAND.COM resides.
  • Edit the PATH command in your AUTOEXEC.BAT file, if you are trying to run a command in another directory that should be accessible from anywhere.
please send me a feed back if this works out thnk you.
Posted on Dec 13, 2008
Plotter does not start, when power is switched on, the text appears: system halted, how the system is possible to start correctly
Heikki, I'm a little confused about what isn't starting. You say that the plotter doesn't start, but you've put your question in a computer forum. Please clarify with the make/model of plotter if that's what the problem is.
If it's your computer, what OS do you use on it?
Jul 10, 2015 | Cooler Master Elite 430 RC-430-KWN1 Black...
Vertical lines on screen looks very bad
maybe your TV have a deffective LCD PANEL,cause those are the systoms of the deffective lcd panel..better to put your unit the nearest service cnter or well trained technician to do the job,,goodluck
Feb 25, 2012 | Samsung SyncMaster 740N (Silver) 17 inch...
Alert! Chipset Heatsink not detected. System halted! is the alert that comes up when I turn my computer. What can I do?
Hi scotteg71121...
The alert is caused by a loose chipset heat sink.
Dell has a self test that prevents further damage by halting the system and displaying the message Alert! Chipset heat sink not detected. System Halted.
The solder joint seems to fail from constant tension and heat.
If you find the missing clip inside the computer you can solder it back in place and reattach the chipset heat sink wire hook.
If you can't find the clip you can replace it by bending a thin piece of wire in a half circle.
You can see a picture of where the clip goes on your computer motherboard by following the link below.
Please take time to rate me
http://www.aplusperfect.com/articles/chipset-heatsink-not-detected
Sep 05, 2011 | Dell Dimension 4600C PC Desktop
My motherboard is asus P5KPL-AM SE when i on it...it detects the hardrives but the lower part was have this msg...."chassis intruded! and system halted! but when i clear the cmos by removing the...
theres many possibilities.... first check if loose connection of cables... also if it helps you might have to jumper hdd ...
and also try replacing cmos battery lastly make sure the chassis sensor button is pressed down when closin lid...
May 21, 2017 | ASUS P4P800-MX Motherboard
Viewsonic VG2021m monitor no longer showing a picture
Hi!
there are possible reasons why your monitor shows nothing on your screen...
First, you need to check if the power cable of your monitor is well connected to a wall socket or AVR (and that you are sure there is supply output current on the AVR or in the wall outlet)
IF found that power cable is fix and secure... my suggestion is you bring the monitor to a credible technician...Because the possible reason why only black is seen on your screen, is because the backlight inverter could be busted already.. the backlight inverter which is located on the upper and lower back edge of the monitor is the light source responsible for giving image display of your lcd monitor.. Another reason could be is a deffective high voltage ballast transformer which is responsible for generating high votlage supply for the backlight....
It is too risky for you to do the repair by yourself without proper knowledge and right tools to do this.. So don't waste time consult a technician and or possible avail of the warranty if there is any...
Hope it is clear now to you..
Much appreciated if you rate this help.. thanks..
May 24, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Water not getting hot
I had the same problem and had it resolved by replacing the heater unit. I found out the heater was open (burned or deffective). I ordered the part (found in eBay) and replaced it by myself. I am not a technician or expert, I downloaded the service manual and tested the heater terminals while on test mode and discovered it was receiving voltage, but its circuit was open. I recommend you do this step before buying any parts, since I read in the forums that another possible failure is the PCB (main board), and in this case voltage is not sent to the heater. I hope it helps, good luck !
Nov 01, 2008 | Dishwashers
ASUS A7N8X-E Deluxe Motherboard Logo
99 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
