Question about Maytag MGR5751AD Gas Kitchen Range
Oven and broiler does not work
My problem is when pressing the oven touch pad or the broiler touch pad the lock light flashes, but nothing happens. The top burners work with no problems. We tried unplugging it for 2 days hoping this would reset the brain but this did'nt help. Is there a reset switch or do wwe have to have the computer replaced?
  • 8,197 Answers
If your oven has a lockout feature, check to see if it's been selected. If so, it will prevent you from using the oven.
Posted on Dec 17, 2008
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
    Here's what the Duet tech sheet says to do:
    1. Press PAUSE/CANCEL button on the touch-pad twice.
    2. Drain the unit, then check that the Drain hose and Drain Pump
    Filter is clear of foreign objects.
    3. Check/ Replace Touch-pad/LED assembly.
    4. Check harness connections.
    5. Check the CCU.
    Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Model SVD48600 door won't open after clean cycle. Fan also locked on. Powered off overnight; no change: "Locked" still displayed
    That is a very complicated unit for the average handyman. It has electronic controls and a relay board, sensors and a locking mechanism. First thing I would check is the locking mechanism and the switch on it. Do this first and let me know if you find one of the switches defective or shorted. While there, check the light switch which is bi-functional being used for the light and also to tell the ERC the door is opened or closed.
    Jenn-Air self-cleaning ovens have a special setting that allows you to clean the oven without chemicals or scrubbing. The oven heats to a temperature higher than used for cooking. The intense heat burns food spills and other residue off oven's inner surfaces.
    Instructions
    1. Remove the broiler pan and any utensils to prevent them from being damaged. Take out the oven racks, since the high heat might discolor them.
    2. Wet a cleaning cloth or sponge with hot water and detergent. Wash off splatters or spills from areas that won't be affected by the cleaning process, including the oven door liner and the oven's front frame. Wipe up any excess grease or spills on the oven floor.
    3. Close the oven door and press the "clean" pad on the unit's touch pad.
    4. Enter the amount of cleaning time. For example, two hours is appropriate for a lightly soiled oven, three for average and four for heavily soiled. Cleaning should start immediately. The oven will remain locked during the cycle.
    5. To delay cleaning, hit the "stop time" pad and enter the desired stop time. For example, if it is 9 p.m. and you want the oven to clean for three hours starting at 10 p.m., key in the numbers 1,0,0.
    6. While the cleaning function operates, use the scouring pads to wash the oven racks and other utensils. Once the cycle ends and the oven unlocks and cools, you can use a damp cloth to pick up any loose or burnt debris inside. Replace the racks, broiler pan and utensils.
    Tell us news.
    May 09, 2010 | Jenn-Air JGW8130DD Gas Single Oven
    I have a GE Model JGBP265BEA1WH and the oven would not work. The broiler & stove top did. I replaced the ignitor and now both the oven and broiler do not work but the burners do. I tried to locate the...
    The burners and its components are totally seperate from oven and there is no controlling shared between them. The problem can be many. Can be the timer control that is locked and not allowing any oven functions. Can be the electricline feeding the oven portion. Can be the oven temp control that tells bake and broil to begin functioning. Can be oven lockout. This is a function that you can turn off by holding the clock or other pad button for 3 seconds. Check your manual to see if I am correct about which touch pad to hold. This is a safety feature that sometimes gets activated and there's no flashing lights telling you about it. Goodluck<Macgivor
    Jan 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Can I clean a TruTemp oven with soap and water without ruining it?
    Yes you could clean it.
    Check few details :-
    t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
    How to self clean
    If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
    The oven door must be closed and all controls set correctly for the cycle to work properly.
    Before a Clean Cycle
    For the first self-clean cycle, we recommend
    venting your kitchen with an open window
    or using a ventilation fan or hood.
    Remove any broiler pan, broiler grid, all
    cookware, probe and any aluminum foil
    from the oven—they cannot withstand the
    high cleaning temperatures.
    NOTE:
    If your oven is equipped with nickel oven
    shelves, remove them before you begin
    the self-clean cycle.
    If your oven is equipped with gray
    porcelain-coated oven shelves, they may
    be left in the oven during the self-clean
    cycle.
    Soil on the front frame of the range and
    outside the gasket on the door will need to
    be cleaned by hand. Clean these areas with
    hot water, soap-filled scouring pads or
    cleansers such as Soft Scrub®. Rinse well
    with clean water and dry.
    Do not clean the gasket. The fiberglass
    material of the oven door gasket cannot
    withstand abrasion. It is essential for the
    gasket to remain intact. If you notice it
    becoming worn or frayed, replace it.
    Wipe up any heavy spillovers on the oven
    bottom.
    Make sure the oven light bulb cover is in
    place and the oven light is off.
    IMPORTANT: The health of some birds
    is extremely sensitive to the fumes given
    off during the self-cleaning cycle of any
    range. Move birds to another well ventilated
    room.
    NOTE: Use caution when opening the upper
    oven after the self-clean cycle has ended.
    The oven may still be hot.
    How to Set the Upper Oven for Cleaning
    On models with Gas/Control Lockout,
    touch and hold the Gas/Control Lockout
    pad for 3 seconds to turn it off.
    NOTE: The surface burners must be turned
    off prior to the self-clean start time.
    If your model has a latch, latch the door.
    Touch the Self Clean pad.
    Using the number pads, enter the
    desired clean time, if a time other than
    4 hours is needed.
    Clean cycle time is normally 4 hours. You can
    change the clean time to any time between
    3 hours and 5 hours, depending on how dirty
    your oven is.
    Touch the Start pad.
    On models without a door latch, the door
    locks automatically. The display will show
    the clean time remaining. It will not be
    possible to open the oven door until the
    temperature drops below the lock
    temperature and the LOCKED DOOR
    light goes off.
    The oven shuts off automatically when the
    clean cycle is complete.
    When the LOCKED DOOR light is off,
    slide the latch handle to the left as far
    as it will go and open the door. If your
    range does not have a latch, the door
    will unlock automatically.
    The words LOCK DOOR will flash and
    the oven control will signal if you set
    the clean cycle and forget to close the
    oven door or forget to latch the door
    on models with a latch.
    To stop a clean cycle, touch the Clear/Off
    pad. When the LOCKED DOOR light goes
    off, indicating the oven has cooled below
    the locking temperature, unlatch the door
    (on models with a latch) and open the door
    How to Delay the Start of Cleaning
    Make sure the clock shows the correct time
    of day.
    the door.
    desired clean time.
    Touch the Delay Start pad. The earliest
    start time you can set will appear in the
    display.
    Using the number pads, enter the time
    of day you want the clean cycle
    to start.
    locks automatically. The display will show the
    start time. It will not be possible to open the
    oven door until the temperature drops below
    the lock temperature and the LOCKED DOOR
    light goes off.
    The words LOCK DOOR will flash and the
    oven control will signal if you set the clean
    cycle and forget to close the oven door or
    forget to latch the door on models with
    a latch.
    pad
    (on models with a latch) and open the door.
    After a Clean Cycle
    You may notice some white ash in the oven.
    Wipe it up with a damp cloth after the
    oven cools.
    If white spots remain, remove them with a
    soap-filled scouring pad and rinse thoroughly
    with a vinegar and water mixture.
    These deposits are usually a salt residue
    that cannot be removed by the clean cycle.
    If the oven is not clean after one clean cycle,
    repeat the cycle.
    You cannot set the oven for cooking until
    the oven is cool enough for the door to
    unlock.
    While the oven is self-cleaning, you can
    touch the Clock pad to display the time
    of day. To return to the clean countdown,
    touch the Cooking Time pad.
    If the shelves become hard to slide, apply a
    small amount of vegetable oil or cooking oil
    to a paper towel and wipe the edges of the
    oven shelves with the paper towel.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
    Touch pad does not work, clocke does, nothing else works
    Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
    simply replacing the touch pad will fix this issue.
    May 30, 2009 | GE JVM2070 Microwave Oven
    Touch pad does not work and flashed FO
    FO- the touch pad is faulty. replace the eoc(electronic oven control)
    May 17, 2009 | Kenmore Ovens
    Mgr5875qdw
    Hello sfgelectric,
    Welcome,
    You said, your broiler and oven won't work. That you set bake and it beeps and the bake light flashes but oven wont light.
    Does the display flash any error codes, or just the bake light?
    Fault codes
    1. BAKE or LOCK may flash rapidly in the display to alert you if there is an error
    or a problem. If BAKE or LOCK appear in the display, press the CANCEL pad.
    2.If BAKE or LOCK continue to flash, disconnect power to the appliance.
    3.Wait a few minutes, and then reconnect power. If the flashing still continues,
    disconnect power to the appliance and call an authorized servicer.
    4.If the oven is heavily soiled, excessive flareups may result in a fault code during
    cleaning. Press the CANCEL pad and allow the oven to cool completely, wipe out
    excess soil, then reset
    For most concerns, try these first.
    Check if oven controls have been properly set.
    Check to be sure plug is securely inserted into receptacle.
    Check or re-set circuit breaker. Check or replace fuse.
    Check power supply
    I'll check the repair manual to see what I can find.
    Let me know how it goes.
    Perhaps this will fix a glitch.
    Huuum
    Remember to leave a rating.
    Oct 16, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
    Beeping, flashing, oven door locked, display shows F-1
    F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
    Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
    Maytag MGR5751AD Gas Kitchen Range Logo
    197 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    gbob59
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
