Compaq Presario F700 wont boot
When I turn on my laptop it acts like it's going to start up normally but then a few seconds later it shuts off and reboots itself over and over again. Nothing comes up on my screen and it just reboots itself constantly.
  • 4 more comments
  • songbird151 Dec 12, 2008
    I don't have a boot disk or a Windows CD (my husband claims it didn't come with any). When I turn it on I can't get anything to show up on the screen at all, it shuts off then turns back on then shuts off again like it's in a loop.
  • Anonymous Dec 20, 2008
    I have the exact same problem. have you fixed the problem yet?
  • codingkid Apr 06, 2009
    This happened to my F700 series laptop when I tried updating the BIOS. The screen is completely black (blank) and the computer sounds like it wants to start up (boot), then just goes into a reboot.
    I have tried a hard reset but fear the motherboard BIOS is toast....which means I might as well just buy another laptop (out of warranty). One possibility is the monitor may have been reset to a remote monitory and can be brough back with [FN] +[F4] keys.
  • Anonymous Apr 07, 2009
    Compaq Presario F700 won't boot up after using it all day ....... seemed to be getting a little sluggish through the day but no errors or warnings .... just shut off on its' own and now won't turn on
  • Aaronn83 Apr 13, 2009
    Same Problem... does the Reboot loop, Called Compaq about it... and all they Try to do is Sell me a year of "Phone Support" for 100Bucks. Funny to see my Laptop Break Two weeks after the Warrenty is up.. im Starting to think they Purposly do this stuff.
  • threexra Sep 27, 2009
    MY ONE IS I CHANGE BIOS BOOT FROM CD , BUT WONT BOOT FROM CD WHEN I BOOT/RESTART
I had the same black screen problem with my Compaq Presario f700.
I went to the HP website to troubleshoot and found that a hard reset fixes the blank screen issue.
To perform a Hard Reset, unplug the AC power adapter and remove the battery, and then press and hold down the Power button for about 6 seconds. This will drain any residual charge in the capacitors and reset the power management controls to their default condition.
This fixed my problem.
I hope it helps you.
Best regards!
Posted on Jan 24, 2010
I have been having the exact same problem with the reboot loop. The only way that I can get the laptop to turn on is to remove the battery and the mobo battery and hold down the power button for at least one minute to drain the caps. I then let the laptop sit for at least 30mins, reinstall the batteries and plug it in. Works everytime...
Why does this happen? Well I was just browsing mls.ca looking at houses when it first happened and the screen just went black and I had a 'uh oh' moment. I did a hard reboot and that is when this cycle started. I am certain that the mobo is toast...but then why does it work sometimes???
Oh and I am one week out of warranty :P
Posted on Dec 02, 2009
    Novelist:
  • 59 Answers
Hi songbird151,
This is actually a fairly common problem adn can be caused by lots of things. There are a couple of fixes you might try:
(A) Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how:
1) Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.).
2) Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
B) If the above doesn't work, you might try bypassing the hard drive altogether and booting from a boot disk (if you have one) or your Windows CD. Here's how:
1) Put the CD in the CD drive and turn the computer on.
2) As the computer begins to turn on, you should see the message "Press __ to enter setup" (it's usually F1, F2, or F4 - models vary). Press that key.
3) You should then see the Setup screen for the BIOS ("Built-In Operating System") - using the arrows, find the "boot disk priority" settings and select your CD Drive as the first priority.
4) Exit setup, saving changes (usually by pressing F10). The computer should then boot normally using the CD. If this works, the problem could be a virus on your hard drive. I recommend scanning your computer with your Anti-virus software as soon as it boots up.
There are other possible causes of the problem you described, but these are the two most common ones. If neither of the above fixes works, I'll be happy to offer some other ideas.
Posted on Dec 12, 2008
  • amahfuz31 Sep 30, 2010
    thank you very much
  • 3 Answers
Remove hard drive( all you need to have is a screw driver to remove the 2 screws that hold the cover of the hard drive and to gently pull up the hard drive), turn compute on, screen now comes on fine, shut computer, re-install hard drive, your computer should now be working fine.
This is for the F700 Compaq series.
Posted on Nov 01, 2009
I also HAD the same problem. As I booted the computer I set it on it's side and "tapped" the bottom hoping for a loose connection to make contact. Well I could get it to boot that way now and then so once I had it running I did some system repair stuff and it came up with the "nvainda video driver was missing" So I told it to find it and re-install which it did and it has been working flawlessly since. I know what your thinking that a video driver couldn't do that but I noticed as it installed that things like disk driver and network drivers were part of the install. So it worked for me GOOD LUCK.
Posted on Dec 13, 2009
Have a presaio f700 and it is telling me no operating system found
Posted on Jul 04, 2009
Found this on another site and it worked!
"no, nothing would come on the screen at all, it would not go into safe mode. But... as I read on here, and much to my disbelief a few stern whacks on the back by the cpu fan exit and she booted up today. I guess I'll never shut it off again lol! I've been burning back up data all day just in case."
Posted on Jun 07, 2009
Aii..can someone help me..i can't format my laptop compaq f700.it show boot reseting on the screen..can someone help me...pliz..
Posted on Jan 27, 2010
Hello, I first had this problem long time ago, and I still have it
though, I have a "ghetto" way to bypass the loop rebooting
When I turn on my computer, as soon as I see the blue light on the power button I press and hold ESCAPE and tap it sometimes
and It then the computer reboots
sometimes I have to tap both ESC and DEL buttons then hold them, and it works
hope this helped some people out there.
Posted on Jun 07, 2011
I'm having the same problem with an CompaqF 700 lap top. I don't get any screen at all. No bios, nothing. I tried pluging it up to another monitor and still nothing. I know the operating system to be sound. It started by not booting sometimes. The power button does stay on after several booting attempts but that's it.
Jessie
Posted on Aug 13, 2010
  • Mr Woodberry Aug 15, 2010
    Taking the battery out and unplugging my Compaq F 700 lap top until it completely cools down, got it going again. It gets hot and still want reboot on demand. So, its not that dependable. I think it is going to need a new mother board from what I have been reading else where.
If you press the f10 just during boot-up then you can reload your os without booting from a cd. Most hp and compaq pcs come with a restore partition to restore from. Hope this helps you all.
Posted on May 10, 2010
  • 3 Answers
If you hold down CTRL+ALT and then repeatedly press DEL when the computer is powering up, you'll get it to go past the compaq screen and boot into windows. Once you see the text at the bottom (e.g: PRESS F2 FOR SYSTEM MESSAGES) etc, you don't have to press CTRL+ALT+DEL anymore.
My laptop has the same problem. It starts but after few seconds gives me a options start safe mode , normal , recovery from last etc. You select any one it dump a blue screen with something but before I ready , it reboots again, so I am unable read the problem . I am unable to booth from CD becuase the CD is not working. Any solution to this problem.
Posted on Dec 31, 2009
Compaq Presario M2000 stopped turning on
If there is no power going to the laptop then disconnect battery and hold the reset button in for 30 seconds, then try it again. Sometimes the memory can be damaged which can cause the laptop not to boot..?
Feb 08, 2013 | Compaq Presario M2000 Notebook
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
I have a Compaq Presario F500 When I press the power button all the lights light up for a few seconds then it shuts back off
remove the battery then try to plug the charger directly on your laptop without a battery.. to test if the battery is working properly. if not.. maybe your main board have a problem. just like athe compaq presario of my friend. also mainboard problem.
Jul 10, 2011 | HP Compaq Presario F500 F700 and G6000...
My laptop will not start
OK. When the AC adapter is plugged in the computer should boot and stay on. Most likely the adapter has malfunctioned or the female connector has come loose from the mother board ( a common problem with all laptops). Check your adapter by measuring the output voltage with a voltmeter, taking it to a repair shop, or using it on another computer. If it is bad, get another, if not, disassemble the laptop and resolder the power connector to the board. Test it before complete reassembly and glue the connector to the board with a few tiny spots of five-minute epoxy. The 5 minute stuff is easy to remove with heat if need be. You can find assembly instructions for your laptop on C-net. Repost this if you need more instructions and I will guide you through it.
Good luck to you.
Aug 22, 2009 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario F700 wont boot. Powers up then turns off again a
that means you might have a hardware failure. possible powersupply. check with local shop.
Jun 17, 2009 | HP Compaq Presario F730US Notebook
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
Compaq Presario F700 Laptop power up issue
Remove your cpu/gpu heatsink, apply a ermal bonding, this will prevent shut off because of cpu/gpu overheating(chipset detects temperature faulty in the firsts seconds of operating your laptop), if this didnt resolve your problem, naybe and issue with your Mobo.
Thanks
Please leave feedback
vcrtech
Apr 27, 2009 | Compaq Presario 700 470024-192 Notebook
HP compaq persario F700 No Display
BGA Nvidia chip GPU on motherboard needs REFLOW or REPLACEMENT.
Dec 26, 2008 | HP Compaq Presario F750US
Computers & Internet Logo
26,259 people viewed this question
David Payne
David Payne
